96PlatinumEdition850 Posted December 23, 2007 Report Share Posted December 23, 2007 Could I do that? Why? Why not?I'm in the works of getting another o2 sensor but could I do that?My front o2 sensor doesn't reach the bung in the dp. Link to comment Share on other sites More sharing options...
Dmsee Posted December 23, 2007 Report Share Posted December 23, 2007 Yea ;) Link to comment Share on other sites More sharing options...
96PlatinumEdition850 Posted December 23, 2007 Author Report Share Posted December 23, 2007 Can you tell me what type of wire to use? Gauge? Copper/metal? Thanks man! Link to comment Share on other sites More sharing options...
loudvolvo Posted December 23, 2007 Report Share Posted December 23, 2007 id get an 02 extension harness from the dealership instead of splicing them, the harness is only like 8" long though...i had to use 2 of them for my rear 02. their about $30 ea. Link to comment Share on other sites More sharing options...
JMK33 Posted December 23, 2007 Report Share Posted December 23, 2007 Volvo makes an OEM extension, I dont have the P/N for it but im positve Joseph does. Link to comment Share on other sites More sharing options...
96PlatinumEdition850 Posted December 23, 2007 Author Report Share Posted December 23, 2007 Why not just splice? It's not like splicing is hard and what's the difference between splicing and using a Volvo extension? Also is it bad if an o2 sensor gets water on it? Link to comment Share on other sites More sharing options...
loudvolvo Posted December 23, 2007 Report Share Posted December 23, 2007 yea splicing is easy but the you would have to use wires of the same resistance and material. I was told by the parts manager at the dealership that the 02 sensor might not function properly if it is spliced. if i were you i would just use an extension harness, its a safer bet i think ipd has a picture of them on their website Link to comment Share on other sites More sharing options...
96PlatinumEdition850 Posted December 23, 2007 Author Report Share Posted December 23, 2007 Anyone got a part number for the extension? Link to comment Share on other sites More sharing options...
Dmsee Posted December 23, 2007 Report Share Posted December 23, 2007 Call dealer tomorrow they should be able to provide it for you. Link to comment Share on other sites More sharing options...
Ruhl98t5wag Posted December 24, 2007 Report Share Posted December 24, 2007 Check this out...http://volvospeed.com/vs_forum/index.php?s...ensor+extension Link to comment Share on other sites More sharing options...
Che'_Moderator Posted December 24, 2007 Report Share Posted December 24, 2007 Why not just splice? It's not like splicing is hard and what's the difference between splicing and using a Volvo extension? Also is it bad if an o2 sensor gets water on it?Because O2 wires are solid core and cannot be soldered ;) Link to comment Share on other sites More sharing options...
Auburn T5 Posted December 24, 2007 Report Share Posted December 24, 2007 yea splicing is easy but the you would have to use wires of the same resistance and material. I was told by the parts manager at the dealership that the 02 sensor might not function properly if it is spliced. if i were you i would just use an extension harness, its a safer bet i think ipd has a picture of them on their websiteYour parts manager is wrong. Standard insulated copper wire works just fine. My volvo mechanic has been working on redblock and white block volvos for over 20 years and said he's spliced standard high quality copper cable to extend 02 sensors (both front and back) for years and never had a problem. To hell with paying $30+ for extensions. $.50 extension FTW. Link to comment Share on other sites More sharing options...
Che'_Moderator Posted December 24, 2007 Report Share Posted December 24, 2007 Your parts manager is wrong. Standard insulated copper wire works just fine. My volvo mechanic has been working on redblock and white block volvos for over 20 years and said he's spliced standard high quality copper cable to extend 02 sensors (both front and back) for years and never had a problem. To hell with paying $30+ for extensions. $.50 extension FTW.Bet he does it with EGTs and WBs too. Thats asking for trouble even on a non-heat 02 Link to comment Share on other sites More sharing options...
96PlatinumEdition850 Posted December 26, 2007 Author Report Share Posted December 26, 2007 So I read in the thread posted that it was part #9202715 and that's a wiring harness. Is this wiring harness what I need or is there something out there known as an oxygen sensor extension? Link to comment Share on other sites More sharing options...
96PlatinumEdition850 Posted December 27, 2007 Author Report Share Posted December 27, 2007 Bump, trying to get an answer ASAP so I can order this stuff. Link to comment Share on other sites More sharing options...
