giantrobot9000 Posted December 28, 2007 Report Share Posted December 28, 2007 I did a full tune-up on my 850 Turbo, and after doing the fuel filter and filling the tank,the boost needle has been shooting way over to the right and then hitting fuel cut or something. I love the extra power,but I'm wondering why it is doing this now? It seems like the ecu is preventing it from overboosting or whatever, but I would love to not have the hitch like it has....? Link to comment Share on other sites More sharing options...
Dmsee Posted December 28, 2007 Report Share Posted December 28, 2007 Is it stock? Link to comment Share on other sites More sharing options...
giantrobot9000 Posted December 28, 2007 Author Report Share Posted December 28, 2007 Yeah, as far as I know. :) Link to comment Share on other sites More sharing options...
Nader Posted December 28, 2007 Report Share Posted December 28, 2007 Maybe there is a way to "flash" the your ECU. Like disconnect your battery for a while? Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted December 28, 2007 Report Share Posted December 28, 2007 I'm gonna say you broke/swapped/disconnected the vacuum line the to wastegate when you did the tune up. Inspect all lines to and from the turbo to the TCV asap. Allowing your car to run like that could cause some damage. Link to comment Share on other sites More sharing options...
JVC Posted December 28, 2007 Report Share Posted December 28, 2007 it sounds like its getting the Overboost Code, does it kick it into Limp Home mode afterward? Did you just get this car? Link to comment Share on other sites More sharing options...
giantrobot9000 Posted December 28, 2007 Author Report Share Posted December 28, 2007 it sounds like its getting the Overboost Code, does it kick it into Limp Home mode afterward? Did you just get this car?No, I've had it a while. It doesn't go into limp home mode. It drives great otherwise actually.I'll check the codes and report back....and the vacuum lines, also. I did have the PCV done recently.... Link to comment Share on other sites More sharing options...
Jaxx Posted December 28, 2007 Report Share Posted December 28, 2007 check the lines to the wastegate. its possible they have become disconnected or they have small holes or are torn. it seems that the wastegate isn't opening. Link to comment Share on other sites More sharing options...
