96PlatinumEdition850 Posted January 9, 2008 Author Report Share Posted January 9, 2008 Can't brake boost when racing from a roll which both races were. He's a good driver and I also had a passenger that weighs 150-160. Link to comment Share on other sites More sharing options...
theForgottenone Posted January 9, 2008 Report Share Posted January 9, 2008 Can't brake boost when racing from a roll which both races were. He's a good driver and I also had a passenger that weighs 150-160.Next time, drop that person on the side of the road Link to comment Share on other sites More sharing options...
Account_Deleted_T5M Posted January 9, 2008 Report Share Posted January 9, 2008 Can't brake boost when racing from a roll which both races were. He's a good driver and I also had a passenger that weighs 150-160.I brake boosted 20lbs from a 40 and a 60 roll last night no problems here, but yea i'm a 5-speed, so what you do is lock it in gear so no kick down Link to comment Share on other sites More sharing options...
97Rwagon Posted January 9, 2008 Report Share Posted January 9, 2008 Ive beaten a 05 RSX type S by a length, length and a half on 20psi. Ive lost to a 07 Rsx type-s like i was sitting still on 16psi.Nice kill though. Link to comment Share on other sites More sharing options...
Account_Deleted_T5M Posted January 9, 2008 Report Share Posted January 9, 2008 2006 was the last year they made the rsx Link to comment Share on other sites More sharing options...
97Rwagon Posted January 9, 2008 Report Share Posted January 9, 2008 Well then it was an 06. Link to comment Share on other sites More sharing options...
96PlatinumEdition850 Posted January 10, 2008 Author Report Share Posted January 10, 2008 I brake boosted 20lbs from a 40 and a 60 roll last night no problems here, but yea i'm a 5-speed, so what you do is lock it in gear so no kick downSo put it in like 3 and brake while putting my foot on the gas? Somehow it doesn't seem right which is why I'm questioning it. Never heard of that before. And yea should have dropped the passenger, also had full spare/jack and sub and amp. Link to comment Share on other sites More sharing options...
Account_Deleted_T5M Posted January 10, 2008 Report Share Posted January 10, 2008 So put it in like 3 and brake while putting my foot on the gas? Somehow it doesn't seem right which is why I'm questioning it. Never heard of that before. And yea should have dropped the passenger, also had full spare/jack and sub and amp.100lbs of added weight = roughly .33 added to your 0-60 time, and 1/10th in the 1/4 mile.About brake boosting it's a very common way to stop turbo lag (minimal in your case) I'll give you an example. In 2nd gear at 40mph i'm pretty high up in the rpm range (4k or so) and as i short shift at 5500 due to boost fade, it's not worth it to start in 2nd. So i stay in 3rd at 40mph and brake boost the car to 15-20lbs of boost (foot on brake and accelerator at the same time) this allows you to lift off the brake and have 20lbs of boost immediately instead of me waiting 2 seconds to hit full boost, because by that time he's gonna be at least a car or two up on me. Since i've owned an automatic 850, heres what you do.From a 40 to 50 roll. Get up to that speed in D, then move the shifter back to L, that will lock you in 2nd gear, with rpms in the 4k range, foot on the brake and accelerator to allow boost to build. Three beeps and you should launch like a rocket. After that you can shift to 3 or D and let the car do its jobFrom a 70 roll lock it in 3rd by putting the Shift selector in 3 mode, and do the same thing Link to comment Share on other sites More sharing options...
rynodyno312 Posted January 11, 2008 Report Share Posted January 11, 2008 100lbs of added weight = roughly .33 added to your 0-60 time, and 1/10th in the 1/4 mile.About brake boosting it's a very common way to stop turbo lag (minimal in your case) I'll give you an example. In 2nd gear at 40mph i'm pretty high up in the rpm range (4k or so) and as i short shift at 5500 due to boost fade, it's not worth it to start in 2nd. So i stay in 3rd at 40mph and brake boost the car to 15-20lbs of boost (foot on brake and accelerator at the same time) this allows you to lift off the brake and have 20lbs of boost immediately instead of me waiting 2 seconds to hit full boost, because by that time he's gonna be at least a car or two up on me. Since i've owned an automatic 850, heres what you do.From a 40 to 50 roll. Get up to that speed in D, then move the shifter back to L, that will lock you in 2nd gear, with rpms in the 4k range, foot on the brake and accelerator to allow boost to build. Three beeps and you should launch like a rocket. After that you can shift to 3 or D and let the car do its jobFrom a 70 roll lock it in 3rd by putting the Shift selector in 3 mode, and do the same thingWhat RPM are you brake boosting at, though. It sounds like you would be making high boost at low rpm, which everyone seems to say bends rods. Link to comment Share on other sites More sharing options...
