Sandro Seminara Posted January 11, 2008 Report Share Posted January 11, 2008 Are their such a thing. I believe they may be the culprit of my rear clunking at low speeds. Are the bushings replaceable by themelves or do I need an entire new rear sway bar? Also how can I test to see if the problem is my sway bar? Should I lift the car off the rear wheels and pull on it? Any ideas?RegardsSandro Link to comment Share on other sites More sharing options...
T-5Bandit Posted January 11, 2008 Report Share Posted January 11, 2008 Are their such a thing. I believe they may be the culprit of my rear clunking at low speeds. Are the bushings replaceable by themelves or do I need an entire new rear sway bar? Also how can I test to see if the problem is my sway bar? Should I lift the car off the rear wheels and pull on it? Any ideas?RegardsSandroNo such thing as rear sway bar bushings. Jack up the car a little and look under the to see if there are any broken points in the sway bar. Rear clunking is usually caused by bad upper shock mounts. You can check those from inside the trunk/cargo area. Link to comment Share on other sites More sharing options...
Ozark Lee Posted January 12, 2008 Report Share Posted January 12, 2008 Rear suspension noises often come down to bad end links on the delta arms. They are a bear to change out but it can be done. I did mine and did a writeup that may or may not point you in the right direction.http://www.matthewsvolvosite.com/chat/phpB...pic.php?p=31294...Lee Link to comment Share on other sites More sharing options...
