Pauloil Posted January 12, 2008 Report Share Posted January 12, 2008 my V70xc 99 has connector for accessoriesI need a switched positive and have the following:pos. connection max load1-- battery+(30) 20 A2-- X supply 0,5 A3-- high beam 1 A4-- 1 A5--6-- Rheostat 0,5 A7-- 2 A8-- Earth(31)I wonder if the rheostat is switched and if it is controlled by the switch for the darkness of the dash lightsanyone know what X supply stands for?p.s. pos.=position Link to comment Share on other sites More sharing options...
MrWinkey Posted January 13, 2008 Report Share Posted January 13, 2008 x is probably a switched power from your description. (like key on power only) 30 is always constant + power Link to comment Share on other sites More sharing options...
Pauloil Posted January 14, 2008 Author Report Share Posted January 14, 2008 you're correct2 is switched positivenow my problem is finding contacts for the male part of the Amp 365063-4 accedssory connector volvo put inwithout pins on the male side.I tried without success to make connector for the male side, but haven't given upanyone else use this connector successfully? Link to comment Share on other sites More sharing options...
