scout01 Posted January 15, 2008 Report Share Posted January 15, 2008 What is up!!!! Hey can a transmission whistle when driving. I have mentioned this earlier, but found out that it is not the turbo. Could it be a vaccum leak? Sound is coming from the front of the engine. If anybody can help that would be great. Link to comment Share on other sites More sharing options...
MrWinkey Posted January 16, 2008 Report Share Posted January 16, 2008 AM radio out of tune?Doubt it's the trans Link to comment Share on other sites More sharing options...
loseR99 Posted January 16, 2008 Report Share Posted January 16, 2008 The turbo would be the only thing whistling under the hood. Link to comment Share on other sites More sharing options...
sks40 Posted January 17, 2008 Report Share Posted January 17, 2008 What is up!!!! Hey can a transmission whistle when driving. I have mentioned this earlier, but found out that it is not the turbo. Could it be a vaccum leak? Sound is coming from the front of the engine. If anybody can help that would be great.How about the crank case vent? Not sure what the sound is that you are hearing but I understand that the crank case vent can start whistle when they get clogged. Link to comment Share on other sites More sharing options...
Jax sarondani Posted January 21, 2008 Report Share Posted January 21, 2008 Sounds weird, but make sure it is not your front wheel bearing. I thought, for sure, I had a tranny problem, but it turned out to be a front bearing. Try gettting your car up to the speed where the noise is loudest, and then, put it in neutral, if the noise is still present (likely it will be), then it is probably not you tranny. Link to comment Share on other sites More sharing options...
bciocco Posted January 23, 2008 Report Share Posted January 23, 2008 Sounds weird, but make sure it is not your front wheel bearing. I thought, for sure, I had a tranny problem, but it turned out to be a front bearing. Try gettting your car up to the speed where the noise is loudest, and then, put it in neutral, if the noise is still present (likely it will be), then it is probably not you tranny.Vacuum lines will sometimes whistle. Does it whistle only while driving or at idle as well? Link to comment Share on other sites More sharing options...
scout01 Posted January 24, 2008 Author Report Share Posted January 24, 2008 Vacuum lines will sometimes whistle. Does it whistle only while driving or at idle as well?Driving and it wont let up. Link to comment Share on other sites More sharing options...
