dmelviØØ7 Posted November 20, 2009 Report Share Posted November 20, 2009 I'm moving to "not near Amsterdam"!! Quote Link to comment Share on other sites More sharing options...
Emiel Posted November 20, 2009 Report Share Posted November 20, 2009 Hulp nodig? :lol: Quote Link to comment Share on other sites More sharing options...
Johann Posted November 21, 2009 Author Report Share Posted November 21, 2009 Hulp nodig? Altijd! Auto vasthouden als ik de wielmoeren aandraai.. Hij zal maar om slaan. :D Quote Link to comment Share on other sites More sharing options...
Johann Posted November 23, 2009 Author Report Share Posted November 23, 2009 Well.. at least there is some momentum back in the SD7 project.. Ordered a lot of parts last Friday, most of them came in this morning. Downside is that it's only 10 minutes worth of work on the engine.. First of all there's a dipstick, C30 2.0 engine mount, studs and nuts, C30 2.0 water pump plus pulley, thermostat housing and idler pulley (Is that the correct word?) C30 2.0 exhaust gasket, EGR channel is blocked on the exhaust side also, round alloy plug on the left. And using the gasket as a template I made an EGR blocking plate, Quote Link to comment Share on other sites More sharing options...
Mesoam Posted November 23, 2009 Report Share Posted November 23, 2009 yes idler pulley (or idler wheel) is correct, did you ever get heat in the new shop? Quote Link to comment Share on other sites More sharing options...
Johann Posted November 23, 2009 Author Report Share Posted November 23, 2009 did you ever get heat in the new shop? The shed you mean? It's not heated, only has single layer metal plate as walls. Quote Link to comment Share on other sites More sharing options...
Johann Posted November 24, 2009 Author Report Share Posted November 24, 2009 Some more parts came in today. Coolant divider plus temperature sender housing at the rear of the engine, On top the coil can be mounted. Bypass hose bewteen thermostat housing and the housing at the rear, Sourced a fuel rail from a wreckyard, Plus two hinges for lifting the engine, I couldn't find part numbers for the hinges in VADIS, in fact they weren't even displayed in the pictures. At the dealership it turned out they were displayed in VIDA but not orderable.. Wreckyard had a damaged engine with the hinges still on. Measured the engine and the 2.3 engine mount sits almost an inch higher compared to a 2.0 engine. Need to raise the motormount on the chassis. Quote Link to comment Share on other sites More sharing options...
JCviggen Posted November 24, 2009 Report Share Posted November 24, 2009 At least you're keeping busy :D Quote Link to comment Share on other sites More sharing options...
Johann Posted November 26, 2009 Author Report Share Posted November 26, 2009 Added some more parts, Coil, Driveshaft support, Studs and nuts for the exhaust manifold Alternator and startermotor, Also ordered a custom single mass flywheel as a replacement for the normally used dual mass flywheel. No choice on clutch yet but I think it will be a Sachs sport version. Quote Link to comment Share on other sites More sharing options...
Johann Posted November 30, 2009 Author Report Share Posted November 30, 2009 Sourced a nice aftermarket single mass flywheel with the same mounting sizes as the original dual mass flywheel. Decided to install a stock 2.0 clutch kit for the time being. See how it goes. Reason for doing so is because I couldn't find proper info about which clutch would fit. Depending on how the car performs I will probably install an LSD anyway sometime next year in which case the box needs to come out again. Also mounted the gearbox. Engine is basically ready for install but before doing so I need to strip the SD-C since it is still on the auto lift. Removed the engine management plus loom and Zeitronix Wideband,Front K-Sport brakes, iPD sways, exhaust and the engine with the gearbox. Had to remove the brakes and sways because they are sold. Already sold the machined R manifold, GT30 turbo with it's external wastegated downpipe a while ago. Quote Link to comment Share on other sites More sharing options...
lookforjoe Posted December 1, 2009 Report Share Posted December 1, 2009 Looks like you have your work cut out for you! That motor is chain drive? I looked back but couldn't find your overall plans for this engine/output levels? Quote Link to comment Share on other sites More sharing options...
Johann Posted December 1, 2009 Author Report Share Posted December 1, 2009 That motor is chain drive? Yes. I looked back but couldn't find your overall plans for this engine/output levels? I hope to start with something near 170 crank HP. Depending on how the car performs maybe try to take it over 200. Quote Link to comment Share on other sites More sharing options...
T5shortblock Posted December 2, 2009 Report Share Posted December 2, 2009 What is going on with SD-C are you selling the shell? Quote Link to comment Share on other sites More sharing options...
Johann Posted December 2, 2009 Author Report Share Posted December 2, 2009 What is going on with SD-C are you selling the shell? Selling is said to much but yes. At the time I received the car for free. Now I will offer the body without engine at the cost of the paperwork transfer and suspending the road tax which in total wouldn't cost more than 100 Euro's. Quote Link to comment Share on other sites More sharing options...
Johann Posted December 3, 2009 Author Report Share Posted December 3, 2009 Removed the Sparco seat, steering wheel, intercooler and oil cooler, engine mounts and wheels. Added stock brakes and rims and pushed it out the door.. This is the end for project SD-C. Will start removing the 1.6 engine from the C30 tomorrow. Quote Link to comment Share on other sites More sharing options...
