Angel Eye Group Buy
leurven
I'm apologize all. The prices I quoted were old GB prices. The price for a set of four rings is $110 shipped or $85 shipped for just two rings.
I am going to try and get an even lower price so I will keep you all posted.
  • Replies 98
Are all four (if one is to get the set of four) identical?
Is the size the same for P1 V70 and 850?
If yes for both q's above, then I would have the option to split-install the set of four to my V70 and my 855 then?
Finally (this is subjective), but since only the low-beam is used in my case most of the time, is having the angel eyes around the low-beam ONLY be funny-looking (that is, would it look 'right'?)
I see the pic on first page (Oreo's?) with both bulbs angel-eyed, any picture for low-beam only?
Thanks
I might be interested, I'd have to look at my headlights and figure out what size would work best, these are something that I've wanted for a while. I just have to figure out how it would look.
You can mix and match what you buy. I have no idea what ones will fit the P2 headlights - My thought is the low beams will be larger than the high beams. You can order two of one size and two of another.
Sizes available. Prices for four rings. Subtract $25 for just two rings.
Thinnest - $85 shipped connus: 70mm, 74mm, 75mm, 90mm, 95mm, 105mm, 116mm, **116/75mm, **116/107mm
Medium Thickness - $110 shipped conus: 95mm, **116/70mm, **116/107mm
Thickest - $110 shipped conus: 116mm, **116/75mm
**This means the ring would be the diameter of the first number with a gap the size of the second number - most BMWs use this type of ring. 116mm for example is the diameter and 107mm is the gap size.
95mm medium thickness is the size of the ones used in the 850 pictured in the first post. The thin rings have proven to be a little too thin to put behind fluted lenses as they are not easily visible and don't really create a good angel eye effect. The thickest ones appear to work but can be just too thick.
Kit Includes:
4 DDE Rings
2 Inverter Power Supplies
1 Relay Harness with Remote-On Feature
Mounting System (applicable to some vehicles only)
Instructions (applicable to some vehicles only)
I imagine if you just install low beams in P2 housings it may look ok. You may want to try a photoshop edit and see what you think. It is most common to put in angel eyes in the low beams and high beams, however.
Please note we offer kits for most newer BMWs and Mazdas and some Suburus.
