Sandro Seminara Posted February 6, 2008 Report Share Posted February 6, 2008 Where is the thermo cutoff on the AC Compressor. I see the wire on the front of the AC Compressor, if I disconnect that does that disable the thermo cut off? The compressor is a couple years old and on my old one, I overrode it (forgot how) and it ran for quite a while. ThanksSandro Link to comment Share on other sites More sharing options...
Seagrams Posted February 6, 2008 Report Share Posted February 6, 2008 Where is the thermo cutoff on the AC Compressor. I see the wire on the front of the AC Compressor, if I disconnect that does that disable the thermo cut off? The compressor is a couple years old and on my old one, I overrode it (forgot how) and it ran for quite a while. ThanksSandrodon't know what you mean by thermo cutoff... but if you're talking about the temperature sensor (which i imagine you are) it's accessible from underneath the car, attached along with an electrical connector to the compressor clutch (man time like this i wish i had VADIS). If we are indeed talking about the same part (the thing that tells the compressor to cycle on and off when refrigerant is low and such), idk about overriding it, don't think you'll necessarily ruin anything except the compressor itself. But if you've done it before and it worked, then why not.... Link to comment Share on other sites More sharing options...
Sandro Seminara Posted February 6, 2008 Author Report Share Posted February 6, 2008 Yea it's the bypass. Do I just unplug it from the snap connector on the front? Link to comment Share on other sites More sharing options...
