giantrobot9000 Posted February 14, 2008 Report Share Posted February 14, 2008 I replaced the entire glovebox on my 94 850T because the lock was busted and the previous owner had cut a hole in it.......well, now the replacement has decided to lock shut and I can't get it open with the correct key or anything. 1)What the hell happened?2) How do I get it open without destroying it? Link to comment Share on other sites More sharing options...
Che'_Moderator Posted February 14, 2008 Report Share Posted February 14, 2008 Carefully pry it open ~10mm. Tape of the edges to prevent damage. Then take a hacksaw and cut the latch. you will obviously need a new one but problem fixed. Link to comment Share on other sites More sharing options...
Aequitas_Veritas Posted February 14, 2008 Report Share Posted February 14, 2008 http://quickbrickmotorsports.com/tech_glovebox.htmlthis is what you should have done to prevent it. Link to comment Share on other sites More sharing options...
Guest 850T-5 Posted February 14, 2008 Report Share Posted February 14, 2008 sucks, that happened to me too. What I did was took a small set of bolt cutters that were fairly flat, pried it open at the top, jammed them in and cut the catch clean off. I then replaced it with the revised part that is "supposed" to not do that again, we'll see I guess. if you screw up the door itself, you can always buy another on ebay or swipe one from the JY to install a new lock/latch assembly in or modify it as described. The dealer told me that use cutters and just cut the hinges off but I think the way I did it was best. Link to comment Share on other sites More sharing options...
giantrobot9000 Posted February 16, 2008 Author Report Share Posted February 16, 2008 Great, thanks for the help. I'll try that "fix" for next time. Link to comment Share on other sites More sharing options...
Serge Posted February 17, 2008 Report Share Posted February 17, 2008 Carefully pry it open ~10mm. Tape of the edges to prevent damage. Then take a hacksaw and cut the latch. you will obviously need a new one but problem fixed.Yep, I did that and was in the glove box within 5 minutes. I did the home-brew fix by using a small machine screw to replace the pin that breaks off. It should be a fairly permanent fix. Link to comment Share on other sites More sharing options...
Dmsee Posted February 17, 2008 Report Share Posted February 17, 2008 If anyone needs that latch I got one very cheap Link to comment Share on other sites More sharing options...
