grocerygetter Posted February 22, 2008 Report Share Posted February 22, 2008 My 15G in my 97 T5 is gone, want to replace with a 16T, or 15G if I really cant find a 16T. Link to comment Share on other sites More sharing options...
jonsayre Posted February 22, 2008 Report Share Posted February 22, 2008 I dont quite understand your post, are you looking for a 16T complete turbo? What style exhaust housing? I might have one. Link to comment Share on other sites More sharing options...
grocerygetter Posted February 22, 2008 Author Report Share Posted February 22, 2008 Yes, looking for a complete 16T with a straight housing, came on 98 S70/V70/C70 t5'sHere is a chart:15G - B5234T 225hk/B5234T5 240hk 1994-1995, The old conic outlet15G - B5234T 225hk/B5234T5 240hk 1996-1997, straight outlet form turbine. <-- What I have16T - B5234T4 250hp kom 1996 i 850R man, straight outlet from turbine16T - B5234T3 240hp 1997-1998 finns i S/V/C70 T5, straight oulet from turbine. <-- What I want16T - B5234T3 240hp 1999-2000 finns i S/V/C70 T5, angled outlet from turbine.16T - B5234T3 250hp 2001- alla S60/V70N T5, angled outlet from turbine. Link to comment Share on other sites More sharing options...
jonsayre Posted February 25, 2008 Report Share Posted February 25, 2008 I have a 16-T from a 2001 C-70 with the angled housing you can swap to your straight housing if you want. I want 400 for the whole turbo. I also have a 15g with a conical outlet I will sell you without the turbine housing for 120$ shipped. Link to comment Share on other sites More sharing options...
grocerygetter Posted February 25, 2008 Author Report Share Posted February 25, 2008 I have a 16-T from a 2001 C-70 with the angled housing you can swap to your straight housing if you want. I want 400 for the whole turbo. I also have a 15g with a conical outlet I will sell you without the turbine housing for 120$ shipped.How hard is it to change out the housings? How many miles on the 15G? Link to comment Share on other sites More sharing options...
jonsayre Posted February 26, 2008 Report Share Posted February 26, 2008 How hard is it to change out the housings? How many miles on the 15G?It is especially easy to change out the housings on these turbos. It takes all of five minutes once the turbo is off the car, just release the band clamp(one bolt) then seperate the hosuing from the center section (you may need to carefully use a small chisel) then put the other housing on and tighten band clamp. The 15g has atleast 130,000 miles on it. It still worked fine and there is minimal shaft play. Link to comment Share on other sites More sharing options...
NGB Posted February 26, 2008 Report Share Posted February 26, 2008 Go for the 16THow many miles does it have? Link to comment Share on other sites More sharing options...
