Guest v70awd Posted February 27, 2008 Report Share Posted February 27, 2008 Looking to purchase a P2 wagon from 2004 to 2006. I know that the T5 was dropped around 2003-2004, however I see some 2.5T wagons. Do they share the same specs as the T5, or are they different?Regards, Link to comment Share on other sites More sharing options...
2001T5 Posted February 27, 2008 Report Share Posted February 27, 2008 T-5 = more ALL GLORY TO THE HYPNOTOAD. T-5 came with a 2.3L high pressure turbo motor, around 246hp. Link to comment Share on other sites More sharing options...
Seagrams Posted February 27, 2008 Report Share Posted February 27, 2008 the 2.5T isn't that much of a pig tho at 210hp. My folks have one i drive when my 850's up on blocks, not a bad ride at all. IPD has ECU's for 'em that add a nice amount of gumption if you want it. Link to comment Share on other sites More sharing options...
7 VII 7 Posted February 27, 2008 Report Share Posted February 27, 2008 this is a good question... you can find a lot more 2.5Ts than T5s... plus they are cheaper Link to comment Share on other sites More sharing options...
TurboS60 Posted February 27, 2008 Report Share Posted February 27, 2008 the 2.5T isn't that much of a pig tho at 210hp. My folks have one i drive when my 850's up on blocks, not a bad ride at all. IPD has ECU's for 'em that add a nice amount of gumption if you want it.Thats right, you can chip a 2.5t and youll be around the same power as the t5. Link to comment Share on other sites More sharing options...
Dmsee Posted February 27, 2008 Report Share Posted February 27, 2008 off course they are same as 2.4T or T5. I would say 70% came with 2.4T Link to comment Share on other sites More sharing options...
VTT5 Posted February 27, 2008 Report Share Posted February 27, 2008 Your best choice probably depends on how you intend to drive. The 2.5T hits max torque at ~1600 RPM, so it's basically instantly in the power band. The T5 hits peak torque higher (2600 RPM), but has more top end (HP is ~40 higher in the T5, but the stock torque numbers were very close). Both are fine engines.The T5 had the 2.3L engine at 247 HP through MY04. In MY05, it became a 2.5L R engine putting out 260HP. In MY06, it was gone.... Link to comment Share on other sites More sharing options...
Dmsee Posted February 27, 2008 Report Share Posted February 27, 2008 Your best choice probably depends on how you intend to drive. The 2.5T hits max torque at ~1600 RPM, so it's basically instantly in the power band. The T5 hits peak torque higher (2600 RPM), but has more top end (HP is ~40 higher in the T5, but the stock torque numbers were very close). Both are fine engines.The T5 had the 2.3L engine at 247 HP through MY04. In MY05, it became a 2.5L R engine putting out 260HP. In MY06, it was gone....2.5R engine with 260HP :o Link to comment Share on other sites More sharing options...
Guest v70awd Posted March 4, 2008 Report Share Posted March 4, 2008 Thanks - I appreciate the answers. This is great information. Will most likely get a 2.5T and mod it as I go. Majority of driving is local with a few highway miles a month. An R would be cool, but the specialized tires, AWD and adaptive suspension makes for "too many moving parts". Link to comment Share on other sites More sharing options...
Dmsee Posted March 4, 2008 Report Share Posted March 4, 2008 Thanks - I appreciate the answers. This is great information. Will most likely get a 2.5T and mod it as I go. Majority of driving is local with a few highway miles a month. An R would be cool, but the specialized tires, AWD and adaptive suspension makes for "too many moving parts".Then you better off with a T5 ;) Link to comment Share on other sites More sharing options...
Mogatu'r Posted March 4, 2008 Report Share Posted March 4, 2008 The T5 had the 2.3L engine at 247 HP through MY04. In MY05, it became a 2.5L R engine putting out 260HP. In MY06, it was gone....Didn't the T5 have a 2.4ltr in '05? Link to comment Share on other sites More sharing options...
Dmsee Posted March 4, 2008 Report Share Posted March 4, 2008 Didn't the T5 have a 2.4ltr in '05?Ya, although I would take 2.3 Link to comment Share on other sites More sharing options...
Mogatu'r Posted March 4, 2008 Report Share Posted March 4, 2008 I'd like to know the difference between the 2.3hpt (850's / S70's) and 2.4hpt ('00R's) and 2.4hpt('05 T5). I know for a fact the 2.4hpt in '00R had the forged internals. Link to comment Share on other sites More sharing options...
Guest Guest_Wayne_* Posted March 4, 2008 Report Share Posted March 4, 2008 T-5 = more jerk. T-5 came with a 2.3L high pressure turbo motor, around 246hp.How do the Bilsteins ride? Are they punishing in the T5? Link to comment Share on other sites More sharing options...
VTT5 Posted March 4, 2008 Report Share Posted March 4, 2008 How do the Bilsteins ride? Are they punishing in the T5?I know you didn't ask me, but I have them, too (with Eibach springs). They're a little rough when the car is unloaded (though not enough to be uncomfortable or even to make my wife complain), but with a little weight in back, they're better settled and make for a comfortable ride. Link to comment Share on other sites More sharing options...
