betterthingstodo Posted March 1, 2008 Report Share Posted March 1, 2008 I've got a CEL P0440 EVAP Emission Control System Malifunction so I'm looking around for a vacuum leak and I see this.It's right below my battery and I'm wondering if there should be something attached to the white nipple. Link to comment Share on other sites More sharing options...
I hate haters Posted March 1, 2008 Report Share Posted March 1, 2008 It's for your cruise control. Nothing should be attached to the white nipple.DZI've got a CEL P0440 EVAP Emission Control System Malifunction so I'm looking around for a vacuum leak and I see this.It's right below my battery and I'm wondering if there should be something attached to the white nipple. Link to comment Share on other sites More sharing options...
DonutsDemise Posted March 1, 2008 Report Share Posted March 1, 2008 I've got a CEL P0440 EVAP Emission Control System Malifunction so I'm looking around for a vacuum leak and I see this.last time i got that code i tightened my gas cap and erased the code. CEL stayed off, problem solved. Link to comment Share on other sites More sharing options...
betterthingstodo Posted March 1, 2008 Author Report Share Posted March 1, 2008 last time i got that code i tightened my gas cap and erased the code. CEL stayed off, problem solved.I tried that, except for erasing the code. I may give that a shot as it seems you can chase this problem around unless you find an obvious problem. Link to comment Share on other sites More sharing options...
Abram Posted March 2, 2008 Report Share Posted March 2, 2008 I'm pretty sure I got that code when my SAS valve failed a month or two ago (could be wrong though). Anyways I replaced the valve, cleared the code and all is well. The valve was a little pricey, but only took 10 minutes to change. Search for SAS valve and you can learn how to check it. If it is the valve I was told by the knowledgeable folks on this board that you need to replace it in a timely fashion or you'll fry your air pump. Hope that helps. Link to comment Share on other sites More sharing options...
sconeman Posted March 2, 2008 Report Share Posted March 2, 2008 I'm pretty sure I got that code when my SAS valve failed a month or two ago (could be wrong though). Anyways I replaced the valve, cleared the code and all is well. The valve was a little pricey, but only took 10 minutes to change. Search for SAS valve and you can learn how to check it. If it is the valve I was told by the knowledgeable folks on this board that you need to replace it in a timely fashion or you'll fry your air pump. Hope that helps.I've been wondering what the hell that thing is for 2 months! Mines been relocated making it that much more confusing. Link to comment Share on other sites More sharing options...
