hgray14 Posted March 3, 2008 Report Share Posted March 3, 2008 I see things like the Scan Gauge II code reader from IPD for the 850 from 1996-on that are meant to be plugged into the OMBII port. Both of my 1995 850 Turbos and my 1995 850 T-5R have OMBII ports under the coin holder in the ash tray area. What is different about my cars that a computer like that won't work on my OMBII ports?thanksHouston Link to comment Share on other sites More sharing options...
BEJinFBK Posted March 3, 2008 Report Share Posted March 3, 2008 Way too much to explain here...Get out on Google, Yahoo, Dogpile or something and search "OBD ll". The internet is your friend and the world is at your fingertips! Link to comment Share on other sites More sharing options...
ErikS Posted March 3, 2008 Report Share Posted March 3, 2008 95 was a bastard year as I have both as well. You can still read the codes through the DTC under your hood and clear them. But sometimes they won't clear unless you use a scan tool.WTF Volvo did that nobody knows. I guess they were testing the system out in that model. If someone asks you at Autozone and you tell them its a 95 and they say a scan toll won't work, tell them it will. Link to comment Share on other sites More sharing options...
ErikS Posted March 3, 2008 Report Share Posted March 3, 2008 Nice Name by the way. Link to comment Share on other sites More sharing options...
bottlecap Posted March 3, 2008 Report Share Posted March 3, 2008 I see things like the Scan Gauge II code reader from IPD for the 850 from 1996-on that are meant to be plugged into the OMBII port. Both of my 1995 850 Turbos and my 1995 850 T-5R have OMBII ports under the coin holder in the ash tray area. What is different about my cars that a computer like that won't work on my OMBII ports?thanksHoustonsome 95s have it and some don't (they have obdi). the ones that do have obdii have a limited implementation. both my 95s had it and i was able to read and reset most of the codes the car might through. with the scan gauge you'll also be able to see things like water temp, voltage, rpm, throttle, ignition, etc, but the car doesn't have sensors for everything the scan gauge can display or doesn't have the sensors wired to the system.people say these won't work on a '95 because they won't work on every '95. the standard wasn't required until '96, but it was phased into some cars early, like the 850. -mike Link to comment Share on other sites More sharing options...
hgray14 Posted March 5, 2008 Author Report Share Posted March 5, 2008 some 95s have it and some don't (they have obdi). the ones that do have obdii have a limited implementation. both my 95s had it and i was able to read and reset most of the codes the car might through. with the scan gauge you'll also be able to see things like water temp, voltage, rpm, throttle, ignition, etc, but the car doesn't have sensors for everything the scan gauge can display or doesn't have the sensors wired to the system.people say these won't work on a '95 because they won't work on every '95. the standard wasn't required until '96, but it was phased into some cars early, like the 850. -mikeI got a code reader and it didn't work on my 1995 850 Turbo. I think it has a production date of 1994 while my other 1995 have production dates in early 1995 although my 1995 850 T-5R also doesn't work. Or maybe it is the cheap, generic reader I bought. I am going to try one more.Does anyone know if the OMBII can be updated or am I stuck with what I have? I love to have one that works but am not willing to trade my '95 for a '96 (my 95 is in perfect shape...and is free at this point).Houston Link to comment Share on other sites More sharing options...
ErikS Posted March 5, 2008 Report Share Posted March 5, 2008 Mine was late production 95. Don't know about the OBDII update but I would think not. You may be stuck with popping the hood and using the box. Link to comment Share on other sites More sharing options...
HtownTurboBrick Posted March 5, 2008 Report Share Posted March 5, 2008 I got a code reader and it didn't work on my 1995 850 Turbo. I think it has a production date of 1994 while my other 1995 have production dates in early 1995 although my 1995 850 T-5R also doesn't work. Or maybe it is the cheap, generic reader I bought. I am going to try one more.Does anyone know if the OMBII can be updated or am I stuck with what I have? I love to have one that works but am not willing to trade my '95 for a '96 (my 95 is in perfect shape...and is free at this point).Houstonjust so you know so that in case you go to autozone and they look at you crazy its OBDII not OMBII, not quite sure why you keep refering it that way, but fyi. Link to comment Share on other sites More sharing options...
hgray14 Posted March 8, 2008 Author Report Share Posted March 8, 2008 just so you know so that in case you go to autozone and they look at you crazy its OBDII not OMBII, not quite sure why you keep refering it that way, but fyi.Thanks, I hate making mistakes like that but with so many things in my world looking similiar I must have something else with three letters, starting with 'O' stuck in my head although at present I can't think of what. Link to comment Share on other sites More sharing options...
AlvinL Posted March 8, 2008 Report Share Posted March 8, 2008 OBDII scan tools only read engine emmision codes (P-codes), nothing else.The diagnostic box and VST (Volvo Scan Tool) reads emmision (A2) plus may others such as ABS, SRS, climate, instrument cluster, etc. Any trouble code can be reset unless there is a problem. Get it fixed and it WILL clear. There is one code for ABS that won't clear but it is normal because the car is not moving when checked (you'll know what I mean).If you have a 95 or earlier, don't waste your time with p-codes. If the diagnostic box is broken, get it fixed. It's the best tool around. The dealer makes lots of money without it.Learn to use it. Link to comment Share on other sites More sharing options...
