mikus Posted March 28, 2008 Report Share Posted March 28, 2008 Above looks like all sedan solutions... I'm about to drop one in a wagon. The 3rd seat area (the 2nd tray, further away from the hatch) is perfect-sized but heat/lack of circulation concerns me. Was thinking of under the pass. seat as well. Anybody have comments/thoughts on either? Thanks Link to comment Share on other sites More sharing options...
lookforjoe Posted March 28, 2008 Report Share Posted March 28, 2008 Above looks like all sedan solutions... I'm about to drop one in a wagon. The 3rd seat area (the 2nd tray, further away from the hatch) is perfect-sized but heat/lack of circulation concerns me. Was thinking of under the pass. seat as well. Anybody have comments/thoughts on either? ThanksI put mine on that shelf, not a real large ampChupacabra has two 500W amps in that same flap.... Link to comment Share on other sites More sharing options...
Owned Posted March 28, 2008 Report Share Posted March 28, 2008 That pictures so huge I can't really tell what I'm looking at. Link to comment Share on other sites More sharing options...
mikus Posted March 28, 2008 Report Share Posted March 28, 2008 looks like it's mounted on the door of the shelf area, ie, on the flap you lift up, facing down?If that's what we're seeing and it's working for you I'm sold on that location. Upside-down amps can't dissapate heat as well (not beating up your install spot, just observing) so a lay-flat install should do fine. And there's always a 12V PC fan if not... Link to comment Share on other sites More sharing options...
lookforjoe Posted March 31, 2008 Report Share Posted March 31, 2008 looks like it's mounted on the door of the shelf area, ie, on the flap you lift up, facing down?If that's what we're seeing and it's working for you I'm sold on that location. Upside-down amps can't dissapate heat as well (not beating up your install spot, just observing) so a lay-flat install should do fine. And there's always a 12V PC fan if not.....Fixed the image size & rotation.Never had any heat issues - I used the same location/setup in my 740T and 960 for 5 years prior to moving it over to the XC. It's not a huge amp - Chupacabra has two 500W amps in the same location - I'd ask him if it's exhibited any heat issues. Link to comment Share on other sites More sharing options...
Fake-R Posted April 2, 2008 Report Share Posted April 2, 2008 Above looks like all sedan solutions... I'm about to drop one in a wagon. The 3rd seat area (the 2nd tray, further away from the hatch) is perfect-sized but heat/lack of circulation concerns me. Was thinking of under the pass. seat as well. Anybody have comments/thoughts on either? Thanks..That's where mine are mounted. Link to comment Share on other sites More sharing options...
Owned Posted April 3, 2008 Report Share Posted April 3, 2008 Build a rack for it. Link to comment Share on other sites More sharing options...
NW T5R Posted April 3, 2008 Report Share Posted April 3, 2008 Link to comment Share on other sites More sharing options...
Serge Posted April 3, 2008 Report Share Posted April 3, 2008 Stealth++It's been cleaned up since then.. wiring is MUCH cleaner. Link to comment Share on other sites More sharing options...
NW T5R Posted April 4, 2008 Report Share Posted April 4, 2008 If not already done or the amp has built in fans I would install some fans on a thermal switch/relay otherwise the amp may be damaged. Link to comment Share on other sites More sharing options...
leurven Posted April 7, 2008 Report Share Posted April 7, 2008 Three will fit perfectly in your spare wheel well. What car you putting these in? Link to comment Share on other sites More sharing options...
