hgray14 Posted March 11, 2008 Report Share Posted March 11, 2008 I have been searching for about 20 minutes and can't find a list of years/engines. I have seen one before but can't remember where. Please point me in the right direction.thanksHouston Link to comment Share on other sites More sharing options...
RZT5 Posted March 11, 2008 Report Share Posted March 11, 2008 I found this list on http://www.swededemon.com/turbo/turbolist.htmlI hope its what your looking forEngines and turbochargers12T - B4204T 160hk 1998-1999, S/V/40 twin scroll12T - B4204T5 165hk 2000-, S/V/40 twin scroll12T - B5204T3 225hk ??-?? C7012T - B5204T4 163hk ??-?? C7012T _ B5204T5 180hk ??-?? S6014T - B4194T 200hk 1998-1999 S/V/4014T - B4204T3 200hk 2000- S/V/40 twin scroll14T - B5254T2 200hk ??-?? S60/V7013G - B5254T 193hk 1996-1998, straight outlet from turbine13G - B5244T 193hk 1999-2000, angled outlet from turbine13G - B5244T 200hk 2001, angled outlet from turbine15G - B5234T 225hk/B5234T5 240hk 1994-1995, The old conic outlet15G - B5234T 225hk/B5234T5 240hk 1996, straight outlet form turbine.16T - B5234T4 250hp kom 1996 i 850R man, straight outlet from turbine16T - B5234T3 240hp 1997-1998 finns i S/V/C70 T5, straight oulet from turbine.16T - B5234T3 240hp 1999-2000 finns i S/V/C70 T5, angled outlet from turbine.16T - B5234T3 250hp 2001- alla S60/V70N T5, angled outlet from turbine.18T - B5234T4 250hp 1997-1998 only S/V70R man FWD/AWD, 275/60 wastegate and straight outletform turbine.18T - B5234RT 250hp 1999 only V70R AWD, 4-vxl aut, 300/70 wastegate and angled outlet form turbine.19T - B5244RT 265hp 2000 endast V70R AWD, 5-vxl aut, 300/70 wastegate and angled outlet form turbine. Link to comment Share on other sites More sharing options...
sconeman Posted March 11, 2008 Report Share Posted March 11, 2008 http://volvospeed.com/vs_forum/index.php?showtopic=21017 Link to comment Share on other sites More sharing options...
hgray14 Posted March 11, 2008 Author Report Share Posted March 11, 2008 Which years/engines were low pressure turbos and which ones were high pressure?I have a 1995 850 Turbo and a 1995 850 T-5R. Both engines are the same, other than ECU, right?thanksHouston Link to comment Share on other sites More sharing options...
JHEIII874T5M Posted March 11, 2008 Report Share Posted March 11, 2008 Yes, both your 850s have the same engine, aside from ECU.Only LPT 850 was the 1997 850 GLT. It uses Motronic 4.4. Essentially identical to the 98 S70 GLT. Link to comment Share on other sites More sharing options...
Skaggs Posted March 11, 2008 Report Share Posted March 11, 2008 i had a motor in my 95 turbo blow at 150,xxx now i have the motor out of a 96 R with 98,xxxSweet! Link to comment Share on other sites More sharing options...
hgray14 Posted March 12, 2008 Author Report Share Posted March 12, 2008 Yes, both your 850s have the same engine, aside from ECU.Only LPT 850 was the 1997 850 GLT. It uses Motronic 4.4. Essentially identical to the 98 S70 GLT.That is interesting. The parts car I just purchased (1995 850 Turbo with all sorts of performance upgrades including IPD ECU and Exhaust) has a "Motronic 4.4+ by Ipd" sticker on the back window. Was the kid who previously owned it just fooling around with stickers or could it mean something? I am pretty sure the engine is stock other than the IPD ECU which I have tested in my other Turbo and it works great.Houston Link to comment Share on other sites More sharing options...
maiku Posted March 12, 2008 Report Share Posted March 12, 2008 i doubt it's running M4.4 unless they completely rewired the car... Link to comment Share on other sites More sharing options...
Boost_Junky Posted March 12, 2008 Report Share Posted March 12, 2008 Better than starting a new thread. Which of these engines is the best for building the internals to take a large turbo and high boost? I think you would know JHEIII. Link to comment Share on other sites More sharing options...
HtownTurboBrick Posted March 12, 2008 Report Share Posted March 12, 2008 all the 2.3's are the same. Except the 96 and 97 R's have a better oil pan, more baffaling for cooling. Other then that its the same. Link to comment Share on other sites More sharing options...
EricF Posted March 12, 2008 Report Share Posted March 12, 2008 Better than starting a new thread. Which of these engines is the best for building the internals to take a large turbo and high boost? I think you would know JHEIII.The two RT engines at the end of the list. Link to comment Share on other sites More sharing options...
Boost_Junky Posted March 12, 2008 Report Share Posted March 12, 2008 The two RT engines at the end of the list.Any reason why? Link to comment Share on other sites More sharing options...
Fudge_Brownie Posted March 12, 2008 Report Share Posted March 12, 2008 They have variable valve timing and stronger internals. They will not be able to run in your car though. Known as the ME7 (opposed to M4.4/M4.3) or 99+ engines. Link to comment Share on other sites More sharing options...
Chilled man Posted March 12, 2008 Report Share Posted March 12, 2008 They have variable valve timing and stronger internals. They will not be able to run in your car though. Known as the ME7 (opposed to M4.4/M4.3) or 99+ engines. and they both have ETM so I would stick with 2.3L R or T5 engines Link to comment Share on other sites More sharing options...
EricF Posted March 12, 2008 Report Share Posted March 12, 2008 It really depends on the level of your build and how far into things you want to get... But they are the nicest block castings and probably have some other things nice about them which I do not know because I'm not all that familiar with them. These things may or may not matter depending upon what you're looking to do and what your goals are.For most projects the 850 T5 engine is going to be just fine. Link to comment Share on other sites More sharing options...
