gatlin Posted March 14, 2008 Report Share Posted March 14, 2008 Good morning.I searched, but I could not find an answer...I'm trying to clean up the Sirius install in my '98 S70 T5. I have the factory SC901 stereo with the Blizsafe RCA adapter into the CD changer plug. The Sirius unit is the Sportster 4, which is powered with 5 volt rather than 12 volt. I'm currently powering the Sirius unit with the 5v cigarette adapter that came with it. Obviously, this is ugly.Does anyone know if there is 5v power anywhere in my car that I can tap into to power the Sirius unit and get rid of the ugly cigarette adapter?Thanks for your help.Gatlin Link to comment Share on other sites More sharing options...
rwb Posted March 14, 2008 Report Share Posted March 14, 2008 For the 5v for my XM I used the cigarette adapter and simply soldered on the positive and negative wires and hooked them up to 12v. Then I just hid the adapter behind the radio. Link to comment Share on other sites More sharing options...
CAPT_BLOTTO Posted March 16, 2008 Report Share Posted March 16, 2008 do not cut off the cigarette lighter adapter. Theres a fuse and other stuff in there and there's an easy way to do it. just go to your local auto parts store and get this: Link to comment Share on other sites More sharing options...
crazykn Posted March 16, 2008 Report Share Posted March 16, 2008 If you have some soldering skills and understand some simple electronics, you can purchase a voltage regulator chip from radioshack that will handle the job nicely and be discrete. The chip is a LM7805. Which will take whatever voltage (as long its above 7V+) and convert it to a straight 5V. Link to comment Share on other sites More sharing options...
Malvasi Posted March 16, 2008 Report Share Posted March 16, 2008 Just wire the adapter it comes with into the harness behind the radio and that will bring it down to 5v from 12v. That is the easiest and safest way to do this. I do this all day long at Circuit City where I am an installer.It works perfect. GL with the install Link to comment Share on other sites More sharing options...
Aequitas_Veritas Posted March 16, 2008 Report Share Posted March 16, 2008 do not cut off the cigarette lighter adapter. Theres a fuse and other stuff in there and there's an easy way to do it. just go to your local auto parts store and get this:i would use this as it requires no modification and is easily reversible if you decide to. I would tape them together though so they dont come apart and hide the while thing behind your dash. Link to comment Share on other sites More sharing options...
