hgray14 Posted March 18, 2008 Report Share Posted March 18, 2008 I was screwing around with the antenna on one of my cars and noticed it clipped in near the drivers tail-light. thanksHouston Link to comment Share on other sites More sharing options...
64pvolvo1800 Posted March 18, 2008 Report Share Posted March 18, 2008 I was screwing around with the antenna on one of my cars and noticed it clipped in near the drivers tail-light. thanksHoustonDo you have a trailer hitch? Might be an isolation module for the trailer harness. Link to comment Share on other sites More sharing options...
hgray14 Posted March 18, 2008 Author Report Share Posted March 18, 2008 Do you have a trailer hitch? Might be an isolation module for the trailer harness.nope, no trailer hitch but maybe there used to be one. I tried to pull it out to look at it but it was stuck in there pretty good and appears to be wired in just like other stock parts.Houston Link to comment Share on other sites More sharing options...
Robert Rike Posted March 18, 2008 Report Share Posted March 18, 2008 nope, no trailer hitch but maybe there used to be one. I tried to pull it out to look at it but it was stuck in there pretty good and appears to be wired in just like other stock parts.HoustonI believe it is the relay box for the tail light out system. If it clips onto the side of a trunk rail on metal sticking up I am pretty sure that is what it is. Forget the exact name of it but it has to do with the bulb out warning system. Link to comment Share on other sites More sharing options...
hgray14 Posted March 18, 2008 Author Report Share Posted March 18, 2008 I believe it is the relay box for the tail light out system. If it clips onto the side of a trunk rail on metal sticking up I am pretty sure that is what it is. Forget the exact name of it but it has to do with the bulb out warning system.ah, that would makes sense. Yes, it is on the metal sticking up from the trunk rail. It seems to be wired as if from the factory but doesn't have bulbs or anything else so it would make sense that is part of the warning system.thanksHouston Link to comment Share on other sites More sharing options...
Cal3thousand Posted March 18, 2008 Report Share Posted March 18, 2008 Its called the Lamp Control Module... if that helps Link to comment Share on other sites More sharing options...
Modus Posted March 18, 2008 Report Share Posted March 18, 2008 Indeed it's the HELLA blown bulb circuit.I cut one of the wires to it so my bulb light never get's illuminated. Link to comment Share on other sites More sharing options...
Chilled man Posted March 18, 2008 Report Share Posted March 18, 2008 Indeed it's the HELLA blown bulb circuit.I cut one of the wires to it so my bulb light never get's illuminated.Do I see airhorn listed in your mods ? NICE Any pics of you set up ? I have a bunch of mine :) Link to comment Share on other sites More sharing options...
Modus Posted March 19, 2008 Report Share Posted March 19, 2008 Do I see airhorn listed in your mods ? NICE Any pics of you set up ? I have a bunch of mine Off topic post.....Indeed Air horn...funny thing is I deleted the sig cause I can't seem to up date the dang thing.Keeps coming up with to many lines. not allowedWT F? grrrrr.Mind you The current set up was neater at one time.... I'm getting a new tank, the one that's in the picture is only a 2 port and well it's a mess with all the brass connections. Shopping a for a 5 Gal 4 or an 8 port.Unfortunately I botched up my trunk liner for the gauge, I was aggravated at that point on the install.The messy set up.175PSI with a 5 gallon tank can = a head ache or making money fixing flats.Horn is located behind Left front side quarter panel. or in front of the splash guard of the left wheel.135dB Hadley horn. plenty to blast the paper boy off his bike. Link to comment Share on other sites More sharing options...
Ozark Lee Posted March 19, 2008 Report Share Posted March 19, 2008 I was screwing around with the antenna on one of my cars and noticed it clipped in near the drivers tail-light. thanksHoustonThat is the bulb failure module for the rear lamps on the car. It monitors the lamps and illuminates the bulb failure lamp on the instrument cluster when a bulb burns out....Lee Link to comment Share on other sites More sharing options...
