Cal3thousand Posted March 19, 2008 Report Share Posted March 19, 2008 So after searching and searching, the jury is still deliberating on which are the best value/quality control arms. (OK so we know scan techs are crap).So many different opinions about a few suppliers, so lets try to get this straight. Please make sure to include the following:original miles before replacing: Manufacturer, source, price:who installed them, did they pre-load before torque-ing:How long did they last or how long has it been (time, miles):additional comments: including, but no limited to "who makes the OE parts" (not who you "think" is the OEM)and..... GO! Link to comment Share on other sites More sharing options...
T-5Bandit Posted March 19, 2008 Report Share Posted March 19, 2008 So after searching and searching, the jury is still deliberating on which are the best value/quality control arms. (OK so we know scan techs are crap).So many different opinions about a few suppliers, so lets try to get this straight. Please make sure to include the following:original miles before replacing: Manufacturer, source, price:who installed them, did they pre-load before torque-ing:How long did they last or how long has it been (time, miles):additional comments: including, but no limited to "who makes the OE parts" (not who you "think" is the OEM)and..... GO!I wouldn't go with anything other than OEM Volvo (Meyle) or TRW. Though some will have varying feedback, I had nothing but problems with both HT and ScanCrap. Link to comment Share on other sites More sharing options...
Cal3thousand Posted March 19, 2008 Author Report Share Posted March 19, 2008 I wouldn't go with anything other than OEM Volvo (Meyle) or TRW. Though some will have varying feedback, I had nothing but problems with both HT and ScanCrap.There was one guy "Swedish Garage" that said Meyle HD's were crap, anyone else with corroborating evidence?:A Piece of Advice as a Swedish & European Car MechanicTo all those who drive their cars everyday, you must change all Front End Parts for the best results.OE , Hamburg Technic or Scantech, none of them will give you 5 years if the Front End is not Fully Tight.2 Very Tight New Control Arms will loosen the older Front End Parts & eventually its own life will get less because of the connection/Circuit of Parts is loose.I will not install a Scantech or Taiwanese Arm with a FAKE VOLVO Logo from Karlyn/STI. Will only install OE or the Hamburg Technic arm, which are as good as they are both Made in Germany at the same Factory.Febi is also a good Brand but even more expensive than OE! Although the Quality is not Better than OE.Meyle HD's Made in Turkey dont hold up that good & i wont touch it with a 10 FT Pole. Link to comment Share on other sites More sharing options...
Cal3thousand Posted March 19, 2008 Author Report Share Posted March 19, 2008 After reading some more stuff on other sites, I have found that TRW is getting good press. Has anyone had a problem with TRWs?Anyone use them? Link to comment Share on other sites More sharing options...
Yellow95 Posted March 19, 2008 Report Share Posted March 19, 2008 Hamburg Technics on all 4 of my cars. never had a problem.Gary Link to comment Share on other sites More sharing options...
Cal3thousand Posted March 19, 2008 Author Report Share Posted March 19, 2008 Hamburg Technics on all 4 of my cars. never had a problem.GaryGary,how many miles do you think you have put on them and did you install yourself? Link to comment Share on other sites More sharing options...
erikv11 Posted March 20, 2008 Report Share Posted March 20, 2008 replaced at 138kHamburg-Technic, FCPgroton, I forget how muchI installed, car on ground before tightening.At 163k, after replacing inner and outer tie rods, I noticed some wander in my steering. So I checked the control arms, ball joints bad on both sides. Bushings are still fine. So are bad at 25k / 2.5 years. Bought OEM replacements waiting for spring to install.additional comments: savings with HT isn't worth the hassle. All my steering parts are new (TRW); I considered TRW arms but just went with genuine Volvo to be sure. Link to comment Share on other sites More sharing options...
Yellow95 Posted March 20, 2008 Report Share Posted March 20, 2008 Gary,how many miles do you think you have put on them and did you install yourself?20,000 on the yellow12000 on the Olive3000 on Big Red6700 on my nieces carPut them all on myslef. Very easy install.Gary Link to comment Share on other sites More sharing options...
7 VII 7 Posted March 20, 2008 Report Share Posted March 20, 2008 20,000 on the yellow12000 on the Olive3000 on Big Red6700 on my nieces carPut them all on myslef. Very easy install.Garyhmmm... numbers are not high enough to give vouch for HTjust get OEM and not to worry. Link to comment Share on other sites More sharing options...
Yellow95 Posted March 20, 2008 Report Share Posted March 20, 2008 hmmm... numbers are not high enough to give vouch for HTjust get OEM and not to worry.Nor are they low enough to say the parts are crap. Just get HT. Gary Link to comment Share on other sites More sharing options...
7 VII 7 Posted March 20, 2008 Report Share Posted March 20, 2008 Nor are they low enough to say the parts are crap. Just get HT. Gary:arob: Link to comment Share on other sites More sharing options...
erikv11 Posted March 20, 2008 Report Share Posted March 20, 2008 Nor are they low enough to say the parts are crap. Just get HT. Garyno the HT arms aren't crap. they just aren't as high quality as Volvo. scan-tech is crap.get HT if 25k is enough, they'll probably last that long. do you drive on bad roads? If you're in Socal then maybe not. I do, all winter and part of the spring until road crews get out. I have a feeling Gary's cars drive on fair-weather FLA pavement? maybe that means his will last a little longer, maybe not. plus every set is different, there is definitely some chance involved. I was expecting 50k minimum, 25k is way too low, won't get burned twice. Link to comment Share on other sites More sharing options...
RockyXL Posted March 20, 2008 Report Share Posted March 20, 2008 How do you know when your control arms are going bad? Ie, what are the symptoms of bad control arms? Link to comment Share on other sites More sharing options...
bdimag Posted March 20, 2008 Report Share Posted March 20, 2008 http://volvospeed.com/vs_forum/index.php?a...ost&id=3395i replaced mine for the ball joines... oe volvo parts ($120 full kit - each side, free shipping @ eeuroparts)got 1500 miles maybe Link to comment Share on other sites More sharing options...
erikv11 Posted March 22, 2008 Report Share Posted March 22, 2008 $80 each side pretty sure they only sell genuine Volvo parts:http://www.tascavolvoparts.com/at that price ($174 shipped) I wouldn't even think about the HT or TRW discussion, it s a no-brainer jump on it Link to comment Share on other sites More sharing options...
