SWM Posted March 24, 2008 Report Share Posted March 24, 2008 Suddenly, my right turn signal blinks double time the normal rate. My left still works normally, and the hazards work normally on both sides. any ideas? this is controlled by a relay or something right? has it failed? Is it an easy replacement? Link to comment Share on other sites More sharing options...
TBM Posted March 24, 2008 Report Share Posted March 24, 2008 Most likely it's just your bulb...change the bulb and see if it goes away. You can just swap the bulbs from one side to the other and see. Link to comment Share on other sites More sharing options...
7 VII 7 Posted March 24, 2008 Report Share Posted March 24, 2008 usually this happens when a bulb is outso your right turn signal will blink fast when one of your right bulbs is out. Link to comment Share on other sites More sharing options...
SWM Posted March 24, 2008 Author Report Share Posted March 24, 2008 ahhh thanks, this is the side my corner unit is busted on too, i bet moisture got in there and fubared the bulb. Ill check it out.... Link to comment Share on other sites More sharing options...
ErikS Posted March 24, 2008 Report Share Posted March 24, 2008 ahhh thanks, this is the side my corner unit is busted on too, i bet moisture got in there and fubared the bulb. Ill check it out....Not just the bulb, but replace the whole harness. Happend to me and a new bulb didn't help. If the harness and wiring is corroded as well, replace the whole thing. Link to comment Share on other sites More sharing options...
Modus Posted March 25, 2008 Report Share Posted March 25, 2008 Including using LED clusters in place of your incandescentsAnyone ever knowtice and newer Cadillac's LED tail light clusters?Their pulsed so they can run longer and not get as hot. What ever the frequency is it's too fast and I get a head ache if i drive behind one.The Hyper flash is a change in resistance of the coil inside the turn relay. Hence fast clicking. Link to comment Share on other sites More sharing options...
