Todd B Posted March 26, 2008 Report Share Posted March 26, 2008 Greetings Everyone...I have an 04 S60 AWD and this car rides like a tank. I can feel EVERY expansion joint in the road and the car takes them very rough. The car is so rough the interior body panels rattle as I go down the road. The dealer says it rides a little rough but cant find anything wrong with the vehicle. Does anyone have a similar experience? Link to comment Share on other sites More sharing options...
ErikS Posted March 26, 2008 Report Share Posted March 26, 2008 What is your tire and wheel setup? Smaller wheels and larger profile tires will give you a cushier ride. Link to comment Share on other sites More sharing options...
Todd B Posted March 26, 2008 Author Report Share Posted March 26, 2008 OEM tires on the vehicle at 35lbs Link to comment Share on other sites More sharing options...
ErikS Posted March 26, 2008 Report Share Posted March 26, 2008 QUOTE (Todd B @ Mar 26 2008, 11:23 AM) <{POST_SNAPBACK}>OEM tires on the vehicle at 35lbsI meant dimensions. Link to comment Share on other sites More sharing options...
maxter81 Posted March 27, 2008 Report Share Posted March 27, 2008 wait a minute... are you telling me that i'm suppose to inflate my tires to 35 lbs??? just want to know because mine are all at 32lbs . i know t5's are stiffer and i got the 17 inches rims with pirellis on but still... Link to comment Share on other sites More sharing options...
Guest 850T-5 Posted March 27, 2008 Report Share Posted March 27, 2008 Probably nothing necessarily that could go wrong to cause it to ride rough unless the struts are shot already, which is unlikely. Sounds to me like the OEM tires might be crappy and not wearing very well. OEM tires, from almost all auto makes usually suck. A lot of times when tires are out of balance or worn irregularly they can cause a rough ride because they don't roll smoothly over bumps and road imperfections. When I've had my tires balanced properly, there's a noticable difference. Maybe try inspecting the tires, rotating and balancing?Also make sure you are checking the pressure cold after not driven for a few hours. I highly recommend using a digital gauge because the mechanical pop up gauges really suck and are horribly inaccurate. Could try knocking the pressure down to 34PSI all the way around if it is within the factory specified range?RE: 32PSI, 32PSI is fine for most OEM wheel / tire setups up to no more than 36PSI for a firmer ride. Link to comment Share on other sites More sharing options...
Pauloil Posted March 27, 2008 Report Share Posted March 27, 2008 i thought volvos were tanks!it's the highway ride I watch the most Link to comment Share on other sites More sharing options...
jb242gt Posted March 27, 2008 Report Share Posted March 27, 2008 i thought volvos were tanks!it's the highway ride I watch the mostThe ride will also depend in the tire compound and temperature. Michelins ride like crap IMO. As stated earlier, profile/aspect ratio play a big part as well. Link to comment Share on other sites More sharing options...
flyfishing3 Posted March 27, 2008 Report Share Posted March 27, 2008 i wonder if the suspension needs going over.glove box rattle is pretty common. some put kitchen cabinet rubber things in there to stop the rattle. rattle could also be the ticket holder on the glass.i ran 38lbs cold on my p2r. i don't know. Link to comment Share on other sites More sharing options...
ArchaicRebel Posted March 27, 2008 Report Share Posted March 27, 2008 The ride will also depend in the tire compound and temperature. Michelins ride like crap IMO. As stated earlier, profile/aspect ratio play a big part as well.I quite agree. I've only had the new car for a few weeks and it came with Michelins, and it could be the taller wheels and lower profile tires, but it's definitely a lot harsher than the S70 T5 I had. It's nowhere near "a tank with excessive panel rattle" on the highway, though, even at speed. It just doesn't take some of the harsh bumps we have in Denver as well, and that's probably a combo of struts/wheel height/tire profile/Michelin tire compound.Of course, I plan to find some Falkens or comparable tires when it comes time for new ones. Asymmetrical tires FTW. Link to comment Share on other sites More sharing options...
