Fudge_Brownie Posted March 31, 2008 Report Share Posted March 31, 2008 where would i notice the vibration?It's a $20 part and easy to change, so if you really hate the vibration, pop it out and sell it on here.I just installed mine and while the vibration has increased SLIGHTLY, I don't know what people are complaining about. Besides, if your mount is shot, its probably not going to feel any worse Visual inspection is easy, stick your head near it and look. For extra verification, blip the throttle a bit while watching, or have someone shift between drive and reverse. (Edit, you have manual trans so nevermind) You'll see if its cracked. The "center" piece begins to crack and its contacting points, and eventually will tear itself free and rock around. Link to comment Share on other sites More sharing options...
SWM Posted March 31, 2008 Author Report Share Posted March 31, 2008 thanks, all this input is appreciated. I read on the IPD site about the vibration too, some people posted it was annoying. I might give it a go anyways, like mentioned, just pop it out and sell it if i have to. Is the OEM rubber mount more difficult for a DIYer? I find these days i'm not about sacrificing ride for performance... My Volvo is 10 years old, and rides REAL tight, so i may not like any added vibrations. Link to comment Share on other sites More sharing options...
7 VII 7 Posted March 31, 2008 Report Share Posted March 31, 2008 thanks, all this input is appreciated. I read on the IPD site about the vibration too, some people posted it was annoying. I might give it a go anyways, like mentioned, just pop it out and sell it if i have to. Is the OEM rubber mount more difficult for a DIYer? I find these days i'm not about sacrificing ride for performance... My Volvo is 10 years old, and rides REAL tight, so i may not like any added vibrations.if you do not like the extra vibration I will buy the IPD from you for sure Link to comment Share on other sites More sharing options...
Yellow95 Posted March 31, 2008 Report Share Posted March 31, 2008 with the POLY the engine and the ride just feel more stable... its like adding rigitity to the car... you will like it... get the IPD one.. I got one from eeuroparts.com and it is not the same quality The upper engine torqe arm bushing will have no effect on "ride stability" at all. Only plus for it is that its easier to install. I dont care how easy it is, I dont like vibration in the cabin. I quickly uninstalled my poly bushing.Gary Link to comment Share on other sites More sharing options...
Fudge_Brownie Posted March 31, 2008 Report Share Posted March 31, 2008 The rubber OEM mount needs to be "pressed" in. You could rig up something like two pieces of strong wood, one on either side of the mount and put a fastener through the middle and crank it down to squeeze the wood together (and thus the mount presses into the hole)But The 2-piece poly mounts are far easier :) Link to comment Share on other sites More sharing options...
SWM Posted March 31, 2008 Author Report Share Posted March 31, 2008 is the OEM mount more difficult to replace? Link to comment Share on other sites More sharing options...
7 VII 7 Posted March 31, 2008 Report Share Posted March 31, 2008 is the OEM mount more difficult to replace?it is 100x more difficult to install than a POLY (if you do not have the tools to do it)I did not want to build a tool to install an OEM bushing if it was just going to failyou could buy the arm with the bushing inside already like OWNED posted... but POLY is the way to goand I did notice stability when I installed my POLY... stability in the engine and acceleration Link to comment Share on other sites More sharing options...
SWM Posted March 31, 2008 Author Report Share Posted March 31, 2008 i got ya, the recomended one is the poly, im just saying, the slight vibration i have now annoys the stuff out of me, so i dont want to re-create anything like it. Is the arm with the bushing install as easy as the poly install? Also, is this pic correct for these 98s? Seems like a different arm? Link to comment Share on other sites More sharing options...
7 VII 7 Posted March 31, 2008 Report Share Posted March 31, 2008 this is the correct one LINKynot sure on how easy it is... but think you can just unbolt the orginal from the block and re-sintall the new onelooks like the correct picture now that I found it through FCP Link to comment Share on other sites More sharing options...
SWM Posted March 31, 2008 Author Report Share Posted March 31, 2008 that linky says for NON Turbo, same for Turbo?found ithttp://www.eeuroparts.com/productdetail.as...1&code=8139 Link to comment Share on other sites More sharing options...
7 VII 7 Posted March 31, 2008 Report Share Posted March 31, 2008 that linky says for NON Turbo, same for Turbo?found ithttp://www.eeuroparts.com/productdetail.as...1&code=8139not sure.. different part numbers ?? Link to comment Share on other sites More sharing options...
Mike_P Posted March 31, 2008 Report Share Posted March 31, 2008 I have a gently used poly bushing from FCP that I will give to you for the cost of priority mail shipping. When I removed it and pressed in an OEM rubber bushing (with $10 in hardware store parts) it took 30 minutes. The OEM install is not hard. Link to comment Share on other sites More sharing options...
SWM Posted April 1, 2008 Author Report Share Posted April 1, 2008 why did you rid yourself of the poly one Mike? the vibration was not something you liked? Link to comment Share on other sites More sharing options...
7 VII 7 Posted April 1, 2008 Report Share Posted April 1, 2008 why did you rid yourself of the poly one Mike? the vibration was not something you liked?just buy the IPD poly mount... if you do not like it... I will buy it from you :) Link to comment Share on other sites More sharing options...
SWM Posted April 1, 2008 Author Report Share Posted April 1, 2008 Mike, is that poly bushing you got from FCP the IPD one? i dont see one on FCPs site? Link to comment Share on other sites More sharing options...
