scout01 Posted April 11, 2008 Report Share Posted April 11, 2008 Question: I have the vehicle being looked at for small maintance work. When I first bought the car you actually can feel the turbo kick in, but now it's a lag in the acceleration and you don't feel the boost. We have checked the turbo by making sure it has not seized up and it is turning. We now are checking the boost sensor and the boost controller to see if they are faulty.Are next step is the boost pressure....any suggestions or answers. Link to comment Share on other sites More sharing options...
theForgottenone Posted April 12, 2008 Report Share Posted April 12, 2008 Check to see if the wastegate got loosen. Do you have a boost guage, if so, how is the boost and it is holding. Check for vacumm line leak/damages.Clean the TB to see if there are an improvement in throttle response.btw, I have a stock 12T for sale. Link to comment Share on other sites More sharing options...
echristodo Posted April 13, 2008 Report Share Posted April 13, 2008 I have a 14T for sale If you had a bad boost pressure sensor or something like that it would be coding. However, you would not necessarily get a CEL for it, are you having your work done at a dealer? Link to comment Share on other sites More sharing options...
scout01 Posted April 14, 2008 Author Report Share Posted April 14, 2008 I have a 14T for sale If you had a bad boost pressure sensor or something like that it would be coding. However, you would not necessarily get a CEL for it, are you having your work done at a dealer?I work at a dealer so one of the guys in the back knows imports, so him and I are slowly trying to find the problem. Link to comment Share on other sites More sharing options...
scout01 Posted April 14, 2008 Author Report Share Posted April 14, 2008 Check to see if the wastegate got loosen. Do you have a boost guage, if so, how is the boost and it is holding. Check for vacumm line leak/damages.Clean the TB to see if there are an improvement in throttle response.btw, I have a stock 12T for sale.He checked for vaccum leaks and found none. He thinks the Turbo sensor is bad. The Turbo does turn by hand, no boost coming when flooring the car. Link to comment Share on other sites More sharing options...
theForgottenone Posted April 14, 2008 Report Share Posted April 14, 2008 He checked for vaccum leaks and found none. He thinks the Turbo sensor is bad. The Turbo does turn by hand, no boost coming when flooring the car.Clean the MAF. Install MBC and bypass BCS completely. However you need to get a boost guage to properly diagnosis this type issue. Link to comment Share on other sites More sharing options...
