Guest aniceto Posted April 11, 2008 Report Share Posted April 11, 2008 before i get flamed,i just have a few questions., i have already done research and im getting mixed answers, but i am planning on buying a 95 o 96 850 volvo and i see that i slot for the cd player i double sized and i want to get a double size dvd player, but all the web sites i go to say they will not fit, but i have seen 850's on car domain and some other sites that have them installed. for example will this on fit ? http://www.crutchfield.com/App/Product/Ite...tures_and_specshttp://www.crutchfield.com/App/Product/Ite...VX710&tp=75in my brothers car his radio size is width 7" 1/2 and height 4" 3/4 more or less. and the one in the link above is w 7" d 7.5" h 3.9" what gets me is i dont see why the web site says it wont fit if the volvo stock cd player is a little bit bigger.......!!!!!???? anyone that has them installed do you have any advice etc... any help would be greatly appriciatedthanks Link to comment Share on other sites More sharing options...
HPTDoh Posted April 11, 2008 Report Share Posted April 11, 2008 You'll probably have to file the opening to make a double-din radio fit. Link to comment Share on other sites More sharing options...
Guest aniceto Posted April 11, 2008 Report Share Posted April 11, 2008 CLOSE THIS POST IM GONNA START A NEW ONE.WITH THE SAME TOPIC. I DIDNT PROFF READ THIS BEFORE POSTING Link to comment Share on other sites More sharing options...
Owned Posted April 12, 2008 Report Share Posted April 12, 2008 It will fit with some work.You don't need two threads about the same exact thing, regardless of if you 'proff' read or not. Link to comment Share on other sites More sharing options...
Guest aniceto Posted April 12, 2008 Report Share Posted April 12, 2008 when you said it will need some work, like what kind of work did you mean? i also found thishttp://www.crutchfield.com/App/Product/Ite...&i=0202DBKTwould that help?thanks Link to comment Share on other sites More sharing options...
Owned Posted April 12, 2008 Report Share Posted April 12, 2008 Depends on the HU.No matter what you'll have to trim the rails on the sides of the dash that that stock HU uses. Link to comment Share on other sites More sharing options...
Guest ANICETO Posted April 12, 2008 Report Share Posted April 12, 2008 ok,so i was planning on just taking it to circuit city to install. do you think they would be able to trim it or no? and if not how would i be able to do it?thanks Link to comment Share on other sites More sharing options...
b3atboxjr Posted April 12, 2008 Report Share Posted April 12, 2008 it's going to take custom work no matter what. there is no adapter or anything to fit a DD(double DIN) unit into our dashes, but any DD unit WILL fit.by custom work, we mean grinding the left and right sides of the radio cavity out a bit, and figuring out a way to keep it still, like using a backstrap or something.I have a DD unit in my 855. what i did is I disassembled the stock stereo, and screwed its side plates to the sides of my new unit, so i could still use the "pulling keys" to slide the new stereo out. good luck!going to any shop, they will charge you a lot, because it's simply a custom job every time. DIY and save money! Link to comment Share on other sites More sharing options...
Livvakt Posted April 12, 2008 Report Share Posted April 12, 2008 CLOSE THIS POST IM GONNA START A NEW ONE.WITH THE SAME TOPIC. I DIDNT PROFF READ THIS BEFORE POSTINGStep 1: Lurk.Step 2: RegisterStep 3: Click "edit" tab after posting, chose between Quick Edit or Full EditStep 4: Wash hands, wipe off on pants.Repeat as necessary.Solves any problems right there ... Oh, and you'll probably have to do some filing to get it to work. Link to comment Share on other sites More sharing options...
Guest aniceto Posted April 12, 2008 Report Share Posted April 12, 2008 it's going to take custom work no matter what. there is no adapter or anything to fit a DD(double DIN) unit into our dashes, but any DD unit WILL fit.by custom work, we mean grinding the left and right sides of the radio cavity out a bit, and figuring out a way to keep it still, like using a backstrap or something.I have a DD unit in my 855. what i did is I disassembled the stock stereo, and screwed its side plates to the sides of my new unit, so i could still use the "pulling keys" to slide the new stereo out. good luck!going to any shop, they will charge you a lot, because it's simply a custom job every time. DIY and save money!i was wondering what didt you use to trim the sides of the radio cavity? would you be able to give me a little advice on what else you did to make it clean? i dont have the car yet so i cant experiment i can only look at my brothers car and try to get some ideas. i am a perfectionest i want everything perfect so if anybody has DO'S and DONT'S can you please let me no? and since i dont no how to install cd players etc... i can only just prep it before i take it to get installed, because im gonna also get my subs and amp installed at the same time. but im sure when i get the new HU and trim it etc and make sure it fits and take it in would that be fine?thank you. Link to comment Share on other sites More sharing options...
b3atboxjr Posted April 18, 2008 Report Share Posted April 18, 2008 i literally took a flat wood file and filed down the inner walls of the stereo cavity.tips on making it clean: be a perfectionist (hey, you already are, imagine that!).seriously, it's your car, if you mess up or rush the job, it's your fault. on the other hand, if you desire that it come out clean, and you do everything possible to ensure such, it will.cd player install is EASY. seriously, just do a search on the board. every company that sells wire harnesses makes harnesses for volvos, do it. Link to comment Share on other sites More sharing options...
Guest aniceto Posted April 18, 2008 Report Share Posted April 18, 2008 i want to install it myself but im getting subs and amp ,alarm etc... and since the 850 has always been my dream car i wants everything done right.the HU ill put that in myself its just the wiring i dont no how to do.but ill take your advice. :) Link to comment Share on other sites More sharing options...
Chilled man Posted April 18, 2008 Report Share Posted April 18, 2008 I just did a Double Din DVD player in my 98R took about 30 min and I used a sawsaw with a long blade to trim those sides out :lol: Link to comment Share on other sites More sharing options...
TRACStar Posted April 27, 2008 Report Share Posted April 27, 2008 I just did a Double Din DVD player in my 98R took about 30 min and I used a sawsaw with a long blade to trim those sides out Pimpin I 'effin love sawzalls Link to comment Share on other sites More sharing options...
maiku Posted April 27, 2008 Report Share Posted April 27, 2008 done and done Link to comment Share on other sites More sharing options...
