negrito211 Posted April 27, 2008 Report Share Posted April 27, 2008 done and donewhat kind of mounting kit do oyu have on you HU? and did it come with the hu or was it separate? do you have any advice? Link to comment Share on other sites More sharing options...
Zeno Posted April 27, 2008 Report Share Posted April 27, 2008 done and donegee man that is freakin awesome, this is the exact same unit I am just about to click buy on e-bay for me! Can you post some more details on mounting on a S70 and some more pictures of the mounted unit?Did that bezel come with the unit? Is this unit any good? Can you configure the button lights to be green just like our panel?And by the way great choice on the unit man! Link to comment Share on other sites More sharing options...
Chilled man Posted April 27, 2008 Report Share Posted April 27, 2008 Heres mine Link to comment Share on other sites More sharing options...
maiku Posted April 27, 2008 Report Share Posted April 27, 2008 there's no cage included (or needed)i had to shave down the stock guides until it fit snuglyneeded some cardboard to get everything to fit tightlythen i screwed a bracket onto the back to secure itthe trim piece came with itdoesn't look too badand you can change the screen colours as well as the illumination/button colours Link to comment Share on other sites More sharing options...
negrito211 Posted May 1, 2008 Report Share Posted May 1, 2008 Heres mine did you have to modify anything else besides the inside of the hole? in other words did you have to modify like the edge of the panel or anything? like the wood grain for example? Link to comment Share on other sites More sharing options...
StoneS70 Posted May 8, 2008 Report Share Posted May 8, 2008 Any ideas on how to make a trim ring to help make it look better? Link to comment Share on other sites More sharing options...
Guest blakbyrd Posted May 21, 2008 Report Share Posted May 21, 2008 In regards to the OP, I just did a complete system upgrade on my 1995 850 Turbo Wagon. I basically went through and explained everything I did on a quick web page I threw together, along with pictures.However, I went back and too the pictures after I was done, so I didnt get any pictures of the head unit cavity, although I removed the speakers to get pictures of how they were installed.You can view the info here: http://www.blakbyrd.com/Car/index.htmlAs for installing the head unit. There are 2 plastic rails on the sides of the head unit cavity that prevent you from properly inserting themounting cage for an aftermarket double din head unit. The rails are plastic, and easy to remove with the proper tools. I cut mine out with a right angle pneumatic die grinder and a thin cutoff wheel. They were gone in about 20 seconds. Afterwards the head unit cage slid in perfectly. However, there were no stock locations for fastening the cage in place, nor any holes to use the metal push tabs the cage supplies. So, I drilled 2 small holes in the bottom of the cage and screwed the cage down with 2 #8 machine screws in the bottom, through the plastic. The screws protrude towards the ash tray but do not touch or conflict with it's usage. I did not drill into the upper part because this was actually the bottom of the climate control. Instead I used some 3M adhesive glue (we use at work anyways) to attach it to the top. At that point, I just wired it up, slid the head unit in and popped on the bezel that cam with the head unit and everything fit just perfectly and looks good. The bezel filled up the hole perfectly and looks about as stock as you will get with such ease. Link to comment Share on other sites More sharing options...
Guest Guest_ggreen67_* Posted June 1, 2008 Report Share Posted June 1, 2008 Crutchfield also said there were no double-din units available for my 960. I had to do a bit of trimming after I took old H/U out, but it fit like a glove. Link to comment Share on other sites More sharing options...
SteveO Posted June 14, 2008 Report Share Posted June 14, 2008 It can be done! I used the cage supplied with my HU. By sanding appx 2mm off of the rails, and notching the cage to snap around the stock rails. I fit my pioneer double din HU in and can still put the stocker back if I so desired. I did a write up on this a long time ago, but I don't know if it's still on the site. Good Luck Link to comment Share on other sites More sharing options...
SmokingJacket Posted June 27, 2008 Report Share Posted June 27, 2008 Crutchfield also said there were no double-din units available for my 960. I had to do a bit of trimming after I took old H/U out, but it fit like a glove.good shot, I will be doing my moms 1997 850 (not a GLT) next week along with a bunch of component speakers...will host lotsa shotsa Link to comment Share on other sites More sharing options...
