Guest Guest_HiTekVolvo_* Posted April 22, 2008 Report Share Posted April 22, 2008 I am about to perform a 110000 mile maintenance on my 1999 s70. This is what I have in mind so far, please suggest anything else that I'm forgetting about.Oil ChangeTranny FlushFuel FilterCabin Air FilterTranny FilterTranny GasketIPD Heavy Duty Tranny MountSeafoam-Engine and TrannySpark PlugsBrake PadsBrake Rotors Link to comment Share on other sites More sharing options...
2001T5 Posted April 22, 2008 Report Share Posted April 22, 2008 Have you changed your timing belt? Link to comment Share on other sites More sharing options...
Guest Guest Posted April 22, 2008 Report Share Posted April 22, 2008 Yes. I already changed it at 102k miles Link to comment Share on other sites More sharing options...
YV1LS53 Posted April 22, 2008 Report Share Posted April 22, 2008 Tranny gasket & filter on a 99?? Link to comment Share on other sites More sharing options...
DonutsDemise Posted April 22, 2008 Report Share Posted April 22, 2008 I am about to perform a 110000 mile maintenance on my 1999 s70. This is what I have in mind so far, please suggest anything else that I'm forgetting about.Oil Change - when was the last time you did it? if it was at 108000 if you do it every 3000 miles why do it early but i doubt its perfectly on track like that Tranny Flush - can't hurt, i did one on Saturday and that old fluid was nasty brown, when was the last one? hope it's not the first!Fuel Filter - 105000 mile service includes this i think, i do mine every 45000 or soCabin Air Filter - i need to do mine! my car was a nice tint of yellow due to pollen season arriving before it rained here for 2 daysTranny Filter - ???Tranny Gasket - ??? drain 2 quarts through the transmission line at the transmission cooler 5 times and refill with two quarts of dex III or 3309 between intervals (i used some valvoline maxlife dex/merc in mine)Spark Plugs - volvo OEM FTW btw, check out the wiring around the coil packs for exposed wires!Brake Pads - how low are they?Brake Rotors - same question, no need to waste money early unless they won't last until your next oil changesounds like a fun filled weekend though :lol: Link to comment Share on other sites More sharing options...
theForgottenone Posted April 23, 2008 Report Share Posted April 23, 2008 Spark plugs and coil pack to go along the list. PCV service?Never heard of tranny filter or gasket on 99+ Volvo. Link to comment Share on other sites More sharing options...
dmelviØØ7 Posted April 23, 2008 Report Share Posted April 23, 2008 There is no 110k service on a 99 car. 97.5k, 105k, 112.5k, 120k.......Every 7500, 120k is the big major service that includes plugs and all of your filters. Link to comment Share on other sites More sharing options...
2001T5 Posted April 23, 2008 Report Share Posted April 23, 2008 Why would you change a coil pack if it's not bad? They will let you know when it's time. lol Link to comment Share on other sites More sharing options...
DonutsDemise Posted April 23, 2008 Report Share Posted April 23, 2008 Why would you change a coil pack if it's not bad? They will let you know when it's time. lol+1 considering they cost $50 a pop. the reason they are there is to lower maintenance costs because they last longer than than components in ignition systems with distributors Link to comment Share on other sites More sharing options...
theForgottenone Posted April 23, 2008 Report Share Posted April 23, 2008 +1 considering they cost $50 a pop. the reason they are there is to lower maintenance costs because they last longer than than components in ignition systems with distributorsIt's call preventative maintenance. Do Volvo OEM distributor and cap last 110K miles?Faulty coil packs can cause lot of issue. Link to comment Share on other sites More sharing options...
DonutsDemise Posted April 23, 2008 Report Share Posted April 23, 2008 It's call preventative maintenance. Do Volvo OEM distributor and cap last 110K miles?Faulty coil packs can cause lot of issue.considering i don't have one in my ignition system.... no? that's why we have packs, they last longer than 30k milesbtw, did you mean distributor cap and rotor? Link to comment Share on other sites More sharing options...
2001T5 Posted April 23, 2008 Report Share Posted April 23, 2008 A coil pack will let you know when it needs to be replaced. Unless you have an extra $250 burning a hole in your pocket, and can't find anything else to buy with it..... Link to comment Share on other sites More sharing options...
