S70 Erik Posted April 27, 2008 Report Share Posted April 27, 2008 I have a 15" woofer and a 3000 watt amp in my S70. My amp has been having problems and I have a strong feeling it is because my alternator is weak. I have a month old 700cca battery so my problem i know is my alternator. So i was wondering does anyone know the specs for a stock S70 alternator? Also does anyone know any good after market alternators for a S70? Link to comment Share on other sites More sharing options...
Chilled man Posted April 27, 2008 Report Share Posted April 27, 2008 3000watts and a 15 are your problems Does the paint still stay on the car anymore ? :P Link to comment Share on other sites More sharing options...
S70 Erik Posted April 27, 2008 Author Report Share Posted April 27, 2008 Haha lets just say it is the loudest system i have heard in a volvo around 130-140 decibels. Link to comment Share on other sites More sharing options...
Get Some Posted April 27, 2008 Report Share Posted April 27, 2008 another little trick might be to wire a switch in to turn your amp on and off manualy before you start the car . thats one way to kill an alternator .. trying to start an engine and boost a 3000 watt amp.. im hoping you already did that tho ... Link to comment Share on other sites More sharing options...
S70 Erik Posted April 27, 2008 Author Report Share Posted April 27, 2008 Yeah my head unit powers it on and off. Link to comment Share on other sites More sharing options...
NGB Posted April 28, 2008 Report Share Posted April 28, 2008 Do a little searching, there are threads around here for HO alts. Link to comment Share on other sites More sharing options...
NGB Posted April 28, 2008 Report Share Posted April 28, 2008 First one that comes to mind is Mean Green, but do a little more searching. Link to comment Share on other sites More sharing options...
Stealth Posted May 3, 2008 Report Share Posted May 3, 2008 You didn't mention when your having problems( at start-up, full volume...) Whether its 100 or 3000 watts your not pulling full current unless your at the higher volumes. When you start the car the amp should not be pulling any more then your HU is. Start with checking all your wiring, most times a bad ground strap is the culprit. Any circuit is only as good as the connections.With that much wattage the wiring should have been reviewed first.. You don't upgrade the motor before the brakes, exhaust and suspension. The power doesn't help if u can't stop!!! Link to comment Share on other sites More sharing options...
Owned Posted May 3, 2008 Report Share Posted May 3, 2008 You didn't mention when your having problems( at start-up, full volume...) Whether its 100 or 3000 watts your not pulling full current unless your at the higher volumes. When you start the car the amp should not be pulling any more then your HU is. Start with checking all your wiring, most times a bad ground strap is the culprit. Any circuit is only as good as the connections.With that much wattage the wiring should have been reviewed first.. You don't upgrade the motor before the brakes, exhaust and suspension. The power doesn't help if u can't stop!!!Right, the fact that is a 3000 watt (probably peak) amp doesn't have anything to do with whatever problems you may have, which you failed to describe in any real detail, btw. "Problems" could be a number of things and the cause is more likely to be your wiring than your amp. It's impossible to diagnose without at least telling us what the problem is. Link to comment Share on other sites More sharing options...
Ghost Shadow Posted May 6, 2008 Report Share Posted May 6, 2008 I have a 15" woofer and a 3000 watt amp in my S70. My amp has been having problems and I have a strong feeling it is because my alternator is weak. I have a month old 700cca battery so my problem i know is my alternator. So i was wondering does anyone know the specs for a stock S70 alternator? Also does anyone know any good after market alternators for a S70? 5 cylinder 2.3 liter (2319cc) with Engine Code B5234T3 : 98-99 Standard 80 10548 - Valeo Optional 100 10280 - Bosch 5 cylinder 2.4 liter (2435cc) with Engine Code B5254S,B5254T : Standard 80 10548 - Valeo Optional 100 10280 - Bosch 5 cylinder 2.3 liter (2319cc) with Engine Code B5234T3 : 2000/2001 All 120 10550 - Bosch 5 cylinder 2.4 liter (2435cc) with Engine Code B5244S,B5244T : All 120 10550 - BoschI am running a rebuilt OEM 200+ amp alternator. My car is at 14.3-14.6 consistantly now. before the uprated alternator, my car was at 13.3-13.7 at the MOST.You should start with upgrading your main battery. Link to comment Share on other sites More sharing options...
Owned Posted May 6, 2008 Report Share Posted May 6, 2008 5 cylinder 2.3 liter (2319cc) with Engine Code B5234T3 : 98-99 Standard 80 10548 - Valeo Optional 100 10280 - Bosch 5 cylinder 2.4 liter (2435cc) with Engine Code B5254S,B5254T : Standard 80 10548 - Valeo Optional 100 10280 - Bosch 5 cylinder 2.3 liter (2319cc) with Engine Code B5234T3 : 2000/2001 All 120 10550 - Bosch 5 cylinder 2.4 liter (2435cc) with Engine Code B5244S,B5244T : All 120 10550 - BoschI am running a rebuilt OEM 200+ amp alternator. My car is at 14.3-14.6 consistantly now. before the uprated alternator, my car was at 13.3-13.7 at the MOST.You should start with upgrading your main battery.GOOD ADVICE!!!!!!!!!Upgrading the battery is awesome because that's what powers the car while it's running AND it will stop his amp 'issue' that he hasn't even described, even if it's going into thermal protect or if grounded it to a piece of plastic. :tup: :tup: Link to comment Share on other sites More sharing options...
