yourshdw Posted May 6, 2008 Report Share Posted May 6, 2008 just wondering if this is the factory bov and if so cant you just remove it a replace with a aftermarket...if so can someone guide me the right way of routing other lines and what do i do with plugi already know about the block off plate for the turbo but honestly im a little lost..thanks... car is a 96 850 turbo Link to comment Share on other sites More sharing options...
Oreo931 Posted May 6, 2008 Report Share Posted May 6, 2008 Negative. That is your IAC. Idle air control.The "BOV" you are thinking of is located on the turbo, it looks like a triangular thing and is actually called a CBV aka compressor bypass valve. If you wanted to add a blow off valve, you could pm Joseph and he could hook you up with a plug and play install kit from forge. You could also get the same kit at www.vivaperformance.com. Typically, you would block off your CBV with a blanking plate when installing a blow off valve, but you dont HAVE to. I will link you to Josephs profile, one second.http://volvospeed.com/vs_forum/index.php?showuser=620 Link to comment Share on other sites More sharing options...
yourshdw Posted May 8, 2008 Author Report Share Posted May 8, 2008 Negative. That is your IAC. Idle air control.The "BOV" you are thinking of is located on the turbo, it looks like a triangular thing and is actually called a CBV aka compressor bypass valve. If you wanted to add a blow off valve, you could pm Joseph and he could hook you up with a plug and play install kit from forge. You could also get the same kit at www.vivaperformance.com. Typically, you would block off your CBV with a blanking plate when installing a blow off valve, but you dont HAVE to. I will link you to Josephs profile, one second.http://volvospeed.com/vs_forum/index.php?showuser=620thanks i thought it wasnt what i thought it was!i do have a super sequential already and plan on putting it in but was questioning using a block off plate?? Link to comment Share on other sites More sharing options...
