Mike H. Posted May 16, 2008 Report Share Posted May 16, 2008 Hi everyone,What size do I use for the led interior conversions? T1-3/4 (5mm)? Thanks.Mike Link to comment Share on other sites More sharing options...
stick70 Posted May 16, 2008 Report Share Posted May 16, 2008 all of the dash switches and windows are 3mm, cc unit is 5mm if you use the stock socketsedit, you have a 05 r, nvm i have no idea, the above is good for 98-00 Link to comment Share on other sites More sharing options...
Mike H. Posted May 16, 2008 Author Report Share Posted May 16, 2008 all of the dash switches and windows are 3mm, cc unit is 5mm if you use the stock socketsedit, you have a 05 r, nvm i have no idea, the above is good for 98-00it's for a 2000 V. crap i don' t think radioshack sells blue 3mm. i want to try one out first before spending the money on fleebay. Link to comment Share on other sites More sharing options...
Mike H. Posted May 16, 2008 Author Report Share Posted May 16, 2008 also, how many do i need for each? Is there a DIY for this? Link to comment Share on other sites More sharing options...
Mike H. Posted May 16, 2008 Author Report Share Posted May 16, 2008 nevermind on the diy request.... how the heck do you edit posts now? Link to comment Share on other sites More sharing options...
T5power Posted May 16, 2008 Report Share Posted May 16, 2008 click the edit button.... it's right next to reply. Link to comment Share on other sites More sharing options...
JVC Posted May 16, 2008 Report Share Posted May 16, 2008 What LED's are you looking to swap to? Switch lights, cluster lights, footwell/overhead lights? I have done cluster and footwell/overhead lights and will possibly be doing the window switch lights in the near future. I just did a write up for the gauge cluster and I may go ahead and do a small easy one for the dome lights etc. The dome lights should be festoons that you can replace with a 39mm LED Festoon Bulb. The back footwell lights in the door for my car were 194's while the front footwell lights were festoons. If you plan to do the switches and not any of the other stuff, then I am no help to you as of right now, but if you have any questions regarding cluster swaps or footwell/overhead dome lights, I recently did it and have many pictures to hopefully help you out.-John Link to comment Share on other sites More sharing options...
Mike H. Posted May 16, 2008 Author Report Share Posted May 16, 2008 What LED's are you looking to swap to? Switch lights, cluster lights, footwell/overhead lights? I have done cluster and footwell/overhead lights and will possibly be doing the window switch lights in the near future. I just did a write up for the gauge cluster and I may go ahead and do a small easy one for the dome lights etc. The dome lights should be festoons that you can replace with a 39mm LED Festoon Bulb. The back footwell lights in the door for my car were 194's while the front footwell lights were festoons. If you plan to do the switches and not any of the other stuff, then I am no help to you as of right now, but if you have any questions regarding cluster swaps or footwell/overhead dome lights, I recently did it and have many pictures to hopefully help you out.-Johneverything... i did more research on it and I guess for the cluster you need a few type B T6 bulbs. i want to know how many 3mm leds to buy and what else I need. I'd rather tackle this all in one weekend rather than one thing at a time. Are 850/70s interchangeable, ie the same? Link to comment Share on other sites More sharing options...
stick70 Posted May 16, 2008 Report Share Posted May 16, 2008 everything... i did more research on it and I guess for the cluster you need a few type B T6 bulbs. i want to know how many 3mm leds to buy and what else I need. I'd rather tackle this all in one weekend rather than one thing at a time. Are 850/70s interchangeable, ie the same?just buy like a 50 pack off of ebay with resistors and youll be good Link to comment Share on other sites More sharing options...
