turbomoose Posted May 18, 2008 Report Share Posted May 18, 2008 Am I correct in thinking the expansion valve goes inside the threaded part of the accumulator?? And would you recommend getting an automatically adjusting expansion valve, or the original valve?The description of the auto adjusting valve says: Automatic adusting oriface tube (expansion valve) for any 93 240, 93-95 940, 93-97 850, 93-97 960, S/V 90 all, C70 98-04, S/V 70 98-00.Installation & Technical Notes: Automatically adjusts to hold temperature at idle. I've never noticed, that I can remember, my A/C getting warm if I'm stuck in traffic for a long time. But is it better to have the auto adjusting valve?Here's the accumulator, that I managed to pin prick puncture when I hit a pot hole last month:Here's the OE expansion valve:Here's the auto adjusting expansion valve: Link to comment Share on other sites More sharing options...
Ozark Lee Posted May 18, 2008 Report Share Posted May 18, 2008 As you kinda figured out that is actually an orifice tube, not an expansion valve. They serve the same function but they operate differently.The orifice tube is located on the low pressure side joint going to the evaporator coil.If you detonated a compressor you need to remove the orifice tube and the accumulator, flush the system, and then replace the orifice and accumulator with new parts....Lee Link to comment Share on other sites More sharing options...
ferrariwagon Posted May 19, 2008 Report Share Posted May 19, 2008 Iwould think if the auto adjusting orifice tube was better volvo would have used it.i would say go oem. Link to comment Share on other sites More sharing options...
turbomoose Posted May 19, 2008 Author Report Share Posted May 19, 2008 Well I took the car back to the dealer today. They're the ones who repaired the subframe and other stuff when I hit the pot hole... They're just making an amendment to the insurance claim and replacing the accumulator and oriface valve. They warned me about the evaporator being a weak link in the system. I told them I knew about it. They said that if they detected any leaks they'd have it replaced too. They'd claim damage from impact. I love them sometimes. I wont get my car back till Wed. :rolleyes: Link to comment Share on other sites More sharing options...
Chilled man Posted May 20, 2008 Report Share Posted May 20, 2008 a sinlge point orifice works perfect in our cars, and all cars unless they have a multiple point evap system in the car we dont so stick with the OEM on this one . Link to comment Share on other sites More sharing options...
turbomoose Posted May 20, 2008 Author Report Share Posted May 20, 2008 If the evap needs to be replaced, should I have them install the volvo evaporator, or is there a known aftermarket part that's less prone to leaks?The evap was replaced under warranty on this car in 2000 with 38K on the clock. The repair receipt said evap update kit. I doubt it's leaking. But who knows. Link to comment Share on other sites More sharing options...
