neworleans Posted May 18, 2008 Report Share Posted May 18, 2008 Hello everyone,I just bought a 2000 Volvo s80 t6 two weeks ago and yesterday when I wanted to start it, it didn't start. I popped up the hood and checked the battery connections first then noticed the fan was still running very slowly so I realized that it drained the battery.I am thinking that it could be a relay problem.. I checked the owners manual to see which relay is for radiator fan but it doesn't say.Do you think this is a relay problem?, if so, can you tell me which relay is to change showing with some pics please??If not, what do you think is the problem??I appericiate your time and help. Link to comment Share on other sites More sharing options...
SkyWriter Posted May 18, 2008 Report Share Posted May 18, 2008 on a hot day, or a hard run the fan will continue running. it shouldn't drain the battery unless the battery was on it's way out already. check the voltage, while the car is on and off, you'll get an idea if the alternative or regulator may be the problem as well.stock alternator is 120amp. you can replace it with a 160 amp if you have plan for power hungry additions. Link to comment Share on other sites More sharing options...
DonutsDemise Posted May 19, 2008 Report Share Posted May 19, 2008 i believe the fan relay is on top of the fan below the upper radiator support. if you follow the power wires from the fan they will lead you to the relay. when had you driven your car last before you went to start it up? the fan will run when you turn your car off if it's hot enough but it shouldn't kill the battery. i would have to agree that the battery is probably the problem. how old is it? Link to comment Share on other sites More sharing options...
neworleans Posted May 19, 2008 Author Report Share Posted May 19, 2008 I drove to work which is not even a mile away from my apt. at around 7am in the morning and I wanted to go home for lunch around 11.30am and when I wanted to started, it was dead, I opened the hood and realized that fan was still running but very slowly, so I realized that it drained the battery... I was thinking about the relay but actually didn't know where the relay was, i thought it could be in the fuse box, but you said that it is somewhere around the fan... The other thing is, there is a recall for the fan so I am planning to go to the volvo dealer tomorrow at lunch and ask about it to see if my car is available for that recall, if not i think it is the relay....I know that it keeps running up to 6 minutes after shutoff but not 4.5 hours is there anyway for you to take a picture of that relay and show it to me so I will know what to look for and what it looks like? I appreciate your help...by the way it is 2000 S80 T6, Link to comment Share on other sites More sharing options...
DonutsDemise Posted May 19, 2008 Report Share Posted May 19, 2008 http://www.pelicanparts.com/cgi-bin/smart/...n=VOL-11006-M76that is what my relay looks like. I couldn't find one for an S80, it's probably different. Link to comment Share on other sites More sharing options...
neworleans Posted May 19, 2008 Author Report Share Posted May 19, 2008 are u sure that s80 radiator fan relay is around the fan too? it is not in the fuse box?thanks.. Link to comment Share on other sites More sharing options...
neworleans Posted May 19, 2008 Author Report Share Posted May 19, 2008 also, i found out that there are 4 recalls for s80's. how am I going to find out that if all these 4 recalls have been applied on my car?? is there anyway to find out about this? does Volvo dealer track the VIN number and see????thanks...here is what i found for the recalls http://www.internetautoguide.com/auto-reca...1591/index.html Link to comment Share on other sites More sharing options...
DonutsDemise Posted May 19, 2008 Report Share Posted May 19, 2008 also, i found out that there are 4 recalls for s80's. how am I going to find out that if all these 4 recalls have been applied on my car?? is there anyway to find out about this? does Volvo dealer track the VIN number and see????thanks...here is what i found for the recalls http://www.internetautoguide.com/auto-reca...1591/index.htmlmaybe someone with an S80 could chime in on exactly where your relay is, i just assumed it might be in the same spot since the vehicle years are close. to find out about the recalls you might be able to call a dealer and give them your VIN, otherwise you could take it to the dealer and they would tell you. Link to comment Share on other sites More sharing options...
neworleans Posted May 19, 2008 Author Report Share Posted May 19, 2008 I just called the volvo customer service and he said that I have the modified model so that option is out I gotta find the damn relay and replace it if i can any s80 owners? help.....Thanks dude for your help... Link to comment Share on other sites More sharing options...
neworleans Posted May 19, 2008 Author Report Share Posted May 19, 2008 Hello everybody,Does anybody know where the Radiator Fan Relay is on a 2000 S80 T6??Thank you... Link to comment Share on other sites More sharing options...
DonutsDemise Posted May 20, 2008 Report Share Posted May 20, 2008 Hello everybody,Does anybody know where the Radiator Fan Relay is on a 2000 S80 T6??Thank you...i wonder if it's integrated into the fan assembly... (on second thought, i doubt it)when i search for the part I can't find it, maybe a wiring diagram will lead you to ithttp://volvo.techno.org.pl/wiring-diagrams.html Link to comment Share on other sites More sharing options...
neworleans Posted May 20, 2008 Author Report Share Posted May 20, 2008 i brought the car to the dealer yesterday and he just called. he said that it is not a relay problem it is the fan. part is Engine cooling fan $300 and labor $210 + taxwhat should I do? Link to comment Share on other sites More sharing options...
rwb Posted May 20, 2008 Report Share Posted May 20, 2008 Check with an autoparts store and see what they charge, if it is less do it your self. Link to comment Share on other sites More sharing options...
DonutsDemise Posted May 20, 2008 Report Share Posted May 20, 2008 do it yourself, its super easy. just get a new fan. $220 off of eeuroparts.com Link to comment Share on other sites More sharing options...
