potroast Posted September 26, 2004 Report Share Posted September 26, 2004 I've got a 93 854 that is really rough to drive; especially over potholes and bad socal freeways. A friend has a 94 855 that rides smooth as silk over the same stuff....Balljoints are new. Tie rod ends are new. Alignment has been recently performed. Tires are new.I need sway bar bushings and links and will be ordering those.What else should I look at to fix my rough-ride? Link to comment Share on other sites More sharing options...
550 Posted September 26, 2004 Report Share Posted September 26, 2004 the worst is you are driving, and you are turning you hit a bump, and you can feel the car slide over just a tiny bit, it is like uuuuh, what heh Link to comment Share on other sites More sharing options...
Bay13 Posted September 26, 2004 Report Share Posted September 26, 2004 In addition to the parts you have mentioned, when is the last time the struts and shocks were replaced, if never, consider them as well?. Link to comment Share on other sites More sharing options...
potroast Posted September 26, 2004 Author Report Share Posted September 26, 2004 the struts appear new because they are black, as where everything else that's not new under there is covered in crud... Is there a way that I can test the struts to see if they are okay or need to be replaced? Link to comment Share on other sites More sharing options...
