SkyWriter Posted May 26, 2008 Report Share Posted May 26, 2008 at some point i thought i saw a write up on someone that made a good attempt at this (i certainly recall the resister drilling link from liquidkernel)i would like to see how some people did, what to look out for and what materials to use. i bought a set of HIDs quite a while ago but waited until i had a spare set of headlights to take my time and do it right.i checked bay13, and searched for it; but came up empty.any help appreciated.btw the bulb has a plastic tube and the mount is molded as part of the base, this can't possibly left on. it would melt, at least how do you take it off with out ruining the bulb.thx! Link to comment Share on other sites More sharing options...
Chilled man Posted May 26, 2008 Report Share Posted May 26, 2008 hole sawsnips to cut the plastic off the HIDs done takes about 20 min dont know why you need another set of headligths this is about one of the easiest mods possilby to do . cut the back of the headlight cover , the ones removable remove old bulb insert new HID bulb plug and play good thing you hate being here :lol: Link to comment Share on other sites More sharing options...
JVC Posted May 26, 2008 Report Share Posted May 26, 2008 The HID's are easy, but projectors I have also been wanting to do. If I get a drivers side headlight for cheap I can give it a shot because I have the passenger side one from Craigslist ($20 cant beat it). Link to comment Share on other sites More sharing options...
SkyWriter Posted May 27, 2008 Author Report Share Posted May 27, 2008 dont know why you need another set of headligths this is about one of the easiest mods possilby to do .i have a parts car. no sense taking the car off the road, or making irreversible changes. good thing you hate being here laugh.gifyou need to read closer; performance, cosmetic, and maint are ok. Link to comment Share on other sites More sharing options...
SkyWriter Posted May 27, 2008 Author Report Share Posted May 27, 2008 The HID's are easy, but projectors I have also been wanting to do. If I get a drivers side headlight for cheap I can give it a shot because I have the passenger side one from Craigslist ($20 cant beat it).i thought you had done one. doesn't the stock bulb cover eliminate viewing the direct filament.if i put projectors on, i don't have to cut ugly filler panels. need to e dome better. Link to comment Share on other sites More sharing options...
Chilled man Posted May 27, 2008 Report Share Posted May 27, 2008 you need to read closer; performance, cosmetic, and maint are ok. :rolleyes: Link to comment Share on other sites More sharing options...
Serge Posted May 29, 2008 Report Share Posted May 29, 2008 Projectors in S80 headlights would be eaassssyyy. The lens comes off with clips, so opening the light is not a problem.. them shoving a nice projector in there (Acura TL most likely) and finishing it off with a shroud would be fairly simple.If you were to have a retrofitter do it, it would probably run you about $200-300 for the retro minus parts. Link to comment Share on other sites More sharing options...
SkyWriter Posted May 30, 2008 Author Report Share Posted May 30, 2008 Projectors in S80 headlights would be eaassssyyy. The lens comes off with clips, so opening the light is not a problem.. them shoving a nice projector in there (Acura TL most likely) and finishing it off with a shroud would be fairly simple.If you were to have a retrofitter do it, it would probably run you about $200-300 for the retro minus parts.thanks, i just don't want to end up with something ugly. i haven't seen many i like. Link to comment Share on other sites More sharing options...
SkyWriter Posted May 31, 2008 Author Report Share Posted May 31, 2008 The HID's are easy, but projectors I have also been wanting to do. If I get a drivers side headlight for cheap I can give it a shot because I have the passenger side one from Craigslist ($20 cant beat it).so, once you snip the clear plastic case off, the base of the bub is the same as an H7 mount? the low beam has suspended can that blocks direct view of the 'filiment' for an H7, is it effective for the HID as well?if i can find the right projector to fit the S80 headlamp, i'll look at doing a full modification. Link to comment Share on other sites More sharing options...
JVC Posted May 31, 2008 Report Share Posted May 31, 2008 The HID's are pretty damn plug and play, as said before. The little cover in the housing that blocks part of the Low beam light is still used, the only thing you have to cut is the cap on the back of the headlght so you can run the wires through it.When I get some money and get a good deal on a drivers side headlight for cheap then I will pick up some TSX projectors and get to work on them. Seems like a summer project I may undertake while my mouth is wired shut for a few weeks.We'll see what happens with all of this and who gets to doing the modification first. Link to comment Share on other sites More sharing options...
SkyWriter Posted June 1, 2008 Author Report Share Posted June 1, 2008 We'll see what happens with all of this and who gets to doing the modification first.i doubt i'll have time to 'compete' i'll try to install the HIDs sometime soon then. Link to comment Share on other sites More sharing options...
SkyWriter Posted June 1, 2008 Author Report Share Posted June 1, 2008 ok, i finally looked at all the pieces. i thought i would do it this afternoon, but i have a May inspection sticker. gotta get that done first. Link to comment Share on other sites More sharing options...
SkyWriter Posted June 3, 2008 Author Report Share Posted June 3, 2008 takes about 20 minapparently you haven't tried it on an S80. a one armed blind man with his thumb sawed off has equal odds with anyone else without taking the headlights out.anyway i got to the point where i got one lit up without a problem; and it's 8K-lishish! Link to comment Share on other sites More sharing options...
JHEIII874T5M Posted June 3, 2008 Report Share Posted June 3, 2008 Congrats, good to hear you got it done. Got any pics? Link to comment Share on other sites More sharing options...
SkyWriter Posted June 3, 2008 Author Report Share Posted June 3, 2008 Congrats, good to hear you got it done. Got any pics?this weekend, i had to pull it out because i'm on my way to cape cod. i'll do it right this weekend. Link to comment Share on other sites More sharing options...
