maciekb2002 Posted May 29, 2008 Report Share Posted May 29, 2008 My brothers 2000 v70, non turbo. His tranny went , 100 + miles , that one is auto 5 speed, Car is in poland but I bought it in USA , and send it to him, he put 5k on it and tranny went. Right now they are heaving huge problem, they try to fight it like a month all ready. Car has new hydro valves, all tranny internals are new, wiring was checked , TCU was replaced. Torque converter replaced. After you reset codes car runs like new, sometimes after 25 miles , some times after 40 car tranny jumps in to limp mode. You have to reset TCU and story repeats . Code for tranny says something about torque converter malfunction, I will get exact number by tomorrow. Please help my brother , Any body may have experience with that stupid Aw50 tranny thanks maciek Link to comment Share on other sites More sharing options...
maciekb2002 Posted May 30, 2008 Author Report Share Posted May 30, 2008 code is P1671 Link to comment Share on other sites More sharing options...
smokin' T5M Posted May 30, 2008 Report Share Posted May 30, 2008 Sounds like the converter is locking up and wont engage. If it wouldn't release then the car would stall when it came to a stop. Should need a new Valve body, if I recall. Link to comment Share on other sites More sharing options...
maciekb2002 Posted June 1, 2008 Author Report Share Posted June 1, 2008 Valve body was replaced with brand new oem part $700, and they swaped converter . Didn't help Link to comment Share on other sites More sharing options...
Y2kV70R Posted June 4, 2008 Report Share Posted June 4, 2008 Make sure they used the right (very expensive) fluid. It has to be JWS-3309 Spec. These trannys are what is called "slip lock", and if you use the wrong fluid, it will not work properly.Have they checked the selonoids? It is possible one of them took a poo...-Shane Link to comment Share on other sites More sharing options...
MrWinkey Posted June 4, 2008 Report Share Posted June 4, 2008 1671 as i recall is a speed sensor code I THINK? Perhaps the fault lies in the ABS module. Is the ABS light on? If so possible module fault. Link to comment Share on other sites More sharing options...
Y2kV70R Posted June 6, 2008 Report Share Posted June 6, 2008 That reminds me... Had the same problem when mine was rebuilt. The sensor that is used to read TRANSMISSION INPUT SHAFT speed does not like al ot of heat. When mine went it was slipping and overheated, and burned up the sensor. If you decide to replace it, don't let the dealer tell you that the AW42-LE sensor will work. It must be the sensor for the AW55-50SN (5spd)-Shane Link to comment Share on other sites More sharing options...
