S70Driva Posted May 31, 2008 Report Share Posted May 31, 2008 I've noticed a tremendous amount of power steering fluid leaking from the passenger side of my 1999 S70 sedan's steering rack, specifically out of the rubber boot. Is this a sign that just the boot is bad, or the seal in the actual rack is bad? Is the boot used to actually contain the fluid or is it used strictly to keep the pignion clear of dirt and debris? Link to comment Share on other sites More sharing options...
dmelviØØ7 Posted May 31, 2008 Report Share Posted May 31, 2008 Boot is just to keep dust out. Sounds like you need a rack :( Link to comment Share on other sites More sharing options...
watertender3c Posted May 31, 2008 Report Share Posted May 31, 2008 I've noticed a tremendous amount of power steering fluid leaking from the passenger side of my 1999 S70 sedan's steering rack, specifically out of the rubber boot. Is this a sign that just the boot is bad, or the seal in the actual rack is bad? Is the boot used to actually contain the fluid or is it used strictly to keep the pignion clear of dirt and debris?From my experience, boot has a break in it allowing water and dirt in, rusting and pitting steering rack shaft, ruining the oil seal. Rack exchange is fairly easy. Rebuilt racks are available for about $250.00. I believe Bay 13 has good instructions for changing rack. In my case removing rack mounting bolts before getting the rack out made it a lot easier. I didn"t realize the bolts were removable until I received the new rack. New hydraulic line connection seals are a must. I tried to reuse existing and ended up with a leak. Connections are sort of a PITA to make and I had to do it twice. Good luck Link to comment Share on other sites More sharing options...
