fastwagonhawaii Posted January 11, 2012 Report Share Posted January 11, 2012 ipd cameron, I am in love with your 240. Just wanted to let you know. Link to comment Share on other sites More sharing options...
lookforjoe Posted January 11, 2012 Report Share Posted January 11, 2012 For now. Just noticed that your MAF is mounted upside down - not good - it needs to be within about 20º of vertical - up top - to prevent moisture accumulation.... Link to comment Share on other sites More sharing options...
Mossback Posted January 11, 2012 Report Share Posted January 11, 2012 My latest bay shot, thanks Rye Link to comment Share on other sites More sharing options...
Timbo Slice Posted January 11, 2012 Report Share Posted January 11, 2012 "Timo want's his engine bay to look like this" engine bay That is pure sex Any reason you haven't upgraded your headlight housings? Link to comment Share on other sites More sharing options...
dublin14 Posted January 11, 2012 Report Share Posted January 11, 2012 Just noticed that your MAF is mounted upside down - not good - it needs to be within about 20º of vertical - up top - to prevent moisture accumulation.... You got a good eye thats for sure... notice a few parts from your car on there That was a day or so after I got it running and the MAF was since moved to stockish postition. Link to comment Share on other sites More sharing options...
TRACStar Posted January 22, 2012 Report Share Posted January 22, 2012 Link to comment Share on other sites More sharing options...
dougy Posted January 22, 2012 Report Share Posted January 22, 2012 Link to comment Share on other sites More sharing options...
ean carr Posted January 25, 2012 Report Share Posted January 25, 2012 Link to comment Share on other sites More sharing options...
s_moneh Posted February 23, 2012 Report Share Posted February 23, 2012 half tucked! otherside needs moar planning and lots more time to tuck! Link to comment Share on other sites More sharing options...
gilber33 Posted February 23, 2012 Report Share Posted February 23, 2012 So jealous. It makes it so much easier that you have a standalone. I really want to re-do mine. But just the thought of cutting the harness in half to relocate the ECUs to the glove box makes me cringe. Where did you pass the wires through from the interior? Link to comment Share on other sites More sharing options...
s_moneh Posted February 23, 2012 Report Share Posted February 23, 2012 None of the wires actually go inside the cabin, all the wires in the engine bay get put through the fusebox before it enters the cabin. so its soo easy to run, mind you its more harder with the stock ecu and all that wiring. So i just put it all in the cowel part up top. soldered and shrink wrapped and that abs line you see caulked by the tower, i ran it through the tower to go with the tuck, your left with sooo much more slack after doing that, thats also why its looped. Also i'm kind of cheesed i used so much more wire then i needed but i was scared of running short wire feeding t through the frame butit all works right now so i'm satisfied, i might shorten the wiring later on if i'm bored Link to comment Share on other sites More sharing options...
gilber33 Posted February 23, 2012 Report Share Posted February 23, 2012 Yeah, that's my issue. It's the main engine harness from the ECU that I have to deal with. I would have to relocate the ECUs inside or something. So I would have to extend the entire harness. Link to comment Share on other sites More sharing options...
s_moneh Posted February 23, 2012 Report Share Posted February 23, 2012 i'll be straight. when i built the motor and what not i got rid of alot of the wiring to begin with. so i was semi tucked for a better tuck later. but from what i had it legit took me 8 hours for just that one side. i cant imagine the amount of time it would take to do the other side with more wires or even if the ecu is there. AND imagine screwing up somewhere in the middle, i would probably cry Link to comment Share on other sites More sharing options...
gilber33 Posted February 23, 2012 Report Share Posted February 23, 2012 i'll be straight. when i built the motor and what not i got rid of alot of the wiring to begin with. so i was semi tucked for a better tuck later. but from what i had it legit took me 8 hours for just that one side. i cant imagine the amount of time it would take to do the other side with more wires or even if the ecu is there. AND imagine screwing up somewhere in the middle, i would probably cry That's kind of why I'm fine where mines at right now. All the relays are relocated in the fender, head light harness in front of the radiator tucked into the headlight bracket thing, Battery reloacted to the trunk. Link to comment Share on other sites More sharing options...
s_moneh Posted February 23, 2012 Report Share Posted February 23, 2012 do u have a insider fender picture? i wanna see what others have done inside the fender Link to comment Share on other sites More sharing options...
