S60RDUDE Posted June 9, 2008 Report Share Posted June 9, 2008 So the T5 has the symptoms of the clutch gap problem. I am going to attempt the fix stated here Clutch Gap Fix The question I have is where on the actual clutch do I measure to get the .04mm gap? See pic in post arrow pointing to the gap but what gap? And where? Any idea what I should use to measure? Link to comment Share on other sites More sharing options...
S60RDUDE Posted June 10, 2008 Author Report Share Posted June 10, 2008 anyone?? what do you use to measure? Link to comment Share on other sites More sharing options...
DonutsDemise Posted June 10, 2008 Report Share Posted June 10, 2008 use a feeler gauge to measure the space between the clutch and the mating face. have you checked out the operation of the clutch? maybe you have a loose wire or low refrigerant/oil Link to comment Share on other sites More sharing options...
Guest Guest_whilst_* Posted June 10, 2008 Report Share Posted June 10, 2008 anyone?? what do you use to measure?Try a set of flat feeler gauges. Brass would be best-non-magnetic. Link to comment Share on other sites More sharing options...
DonutsDemise Posted June 10, 2008 Report Share Posted June 10, 2008 Try a set of flat feeler gauges. Brass would be best-non-magnetic.if the compressor isn't on then the magnet isn't on so a regular feeler gauge would work fine. Link to comment Share on other sites More sharing options...
