smokin' T5M Posted June 18, 2008 Report Share Posted June 18, 2008 Is the water pump pulley supposed to have several teeth missing? Yes. in '94 or '95 they changed the design to that kind of gear on the pump pulleyGlad it all worked out Mike Link to comment Share on other sites More sharing options...
Chilled man Posted June 18, 2008 Report Share Posted June 18, 2008 Yes. in '94 or '95 they changed the design to that kind of gear on the pump pulleyGlad it all worked out Mikehave to be after mid 95 since adams had all the teeth and so did his new one. yeah this engine has some odd things to it to say the least Link to comment Share on other sites More sharing options...
64pvolvo1800 Posted June 18, 2008 Report Share Posted June 18, 2008 Bingo!I forgot that the plastic backing is really all around in there, so I just moved the coolant reservoir and got in there with a mirror, and the tensioner pulley was not in all the way. A little banging around and I got another 3/4 turn on the bolt before it tightened up. I started it up and the whole thing aligns perfectly now, all the way around. Thanks, guys! @Zohan: BTW, I can't see any of the pics that you've posted recently. They're there in the source code, but the images aren't. Is Photobucket down, or do I live downstream from some bad DNS info right now?DAMN LUCKY Mike. You must be living right. If that was mine, the engine would've already spit out little pieces, rolled over, and died. Maybe you should go buy a Lotto ticket man! Link to comment Share on other sites More sharing options...
