Guest Guest_Adam_* Posted June 24, 2008 Report Share Posted June 24, 2008 I recently purchased a 12" L7 Kicker with a Kicker 06ZX750.1 Amp. After installing everything, the bass of the sub is extremely weak, the AMP becomes heated after minutes of play, and there is a distinct smell as well. Are these signs of a blown sub or could it be incorrect wiring. I tried hooking up a friends same exact sub to my setup and the sub sounds perfect. The only reason I am confused is because I just bought the sub from a reliable online source. Any Tips? Link to comment Share on other sites More sharing options...
JVC Posted June 24, 2008 Report Share Posted June 24, 2008 I recently purchased a 12" L7 Kicker with a Kicker 06ZX750.1 Amp. After installing everything, the bass of the sub is extremely weak, the AMP becomes heated after minutes of play, and there is a distinct smell as well. Are these signs of a blown sub or could it be incorrect wiring. I tried hooking up a friends same exact sub to my setup and the sub sounds perfect. The only reason I am confused is because I just bought the sub from a reliable online source. Any Tips?sounds like you wired it wrong, or you haven't adjusted the amp properly for the sub that you are using and are killing it slowly... Link to comment Share on other sites More sharing options...
Y2kV70R Posted June 24, 2008 Report Share Posted June 24, 2008 You have your two voicecoils wired out of phase.... Fix it before you fry your sub. When the voicecoil is not moving, it is not getting cooled, and will overheat and burn up.-Shane Link to comment Share on other sites More sharing options...
Get Some Posted June 24, 2008 Report Share Posted June 24, 2008 def check your ground wire as well Link to comment Share on other sites More sharing options...
