alanL Posted June 27, 2008 Report Share Posted June 27, 2008 the driver's window switch allows the window to go down but not up. if i use the convertible top switch, the window will rise. not sure if it's related but interior dash lights just went out too. any help would be appreciated. thank you. Link to comment Share on other sites More sharing options...
adamjjohn203 Posted June 27, 2008 Report Share Posted June 27, 2008 Take out the switch and pull it apart it not that hard and clean the contacts. I did this on mine when it went down and not up. Link to comment Share on other sites More sharing options...
MrWinkey Posted June 28, 2008 Report Share Posted June 28, 2008 Take out the switch and pull it apart it not that hard and clean the contacts. I did this on mine when it went down and not up.Good advice....if your not up too that you can replace the switch cluster and do yourself a favor and by it from Volvo. I'm sure that is where the problem lies though. ;) Link to comment Share on other sites More sharing options...
Geoffrey Posted July 8, 2008 Report Share Posted July 8, 2008 the driver's window switch allows the window to go down but not up. if i use the convertible top switch, the window will rise. not sure if it's related but interior dash lights just went out too. any help would be appreciated. thank you.I blew a fuse #15 today trying to pry out the bulb in my right visor as it was draining my battery. Trunk dash light was constantly on, chime was incessant, and to top it off driver window wouldn't work except with the all-down feature. Link to comment Share on other sites More sharing options...
