Demosthenes Posted June 28, 2008 Report Share Posted June 28, 2008 So my check engine light has been on for a few months now, i got the codes read, and the code is P0455. i know that i should have just taken it in and gotten it checked out, but i didnt. anyways, today when i first started the car, the engine was idling at about 150 rpms lower than it normally idles at. The second time i started my engine today, it drove for a little while, then the check engine light started blinking, and the little computer that shows my Mpg, average speed, etc, read : Emission System Service Required. when this happened, i lost a good amount of throttle response, and when i acellerate so that it goes above 2500 rpm the engine starts shaking pretty violently and the car sounds pretty weird also. I checked the belts and they are fine i didnt think that was teh problem as it only shakes at a certain rpm. i would appreciate any and all help in this matter. Thanks Link to comment Share on other sites More sharing options...
smokin' T5M Posted June 28, 2008 Report Share Posted June 28, 2008 When the C.E.L. flashes it means a misfire in the system. What year is the car obviously it's P2. I don't know what the generic P0455 means. I'm a VST/VIDA guy. Coils go bad, in which case I would do plugs at the same time. I would have the ETM checked as well depending on the year of the car. For now sounds like you need maintenance.C.E.L. = Check Engine LightVST = Volvo Scan Tool Link to comment Share on other sites More sharing options...
