Auburn T5 Posted July 2, 2008 Report Share Posted July 2, 2008 Tonight we were leaving walmart and though we're aware of the failing ABS module, the actual dash light saying "brake" was on for about a minute then turned off. Does this have anything to do with the abs module? I checked the owner manual and it said to stop and check the brake fluid level. I did this and the fluid is near the top of the reservoir at the max capacity level. The abs module has been crapping out for a while now but this is the first time that brake light has actually turned on that way.should I be concerned? I'm planning on sending the ABS module to victor next week. Link to comment Share on other sites More sharing options...
Dmsee Posted July 2, 2008 Report Share Posted July 2, 2008 No, check your pads Link to comment Share on other sites More sharing options...
MrWinkey Posted July 2, 2008 Report Share Posted July 2, 2008 If the reservoir is full could be the sensor in the master cyl . or possibly the e-brake switch. I don't believe the brake light comes on with a failing module. As for being concerned, if the pedal feels solid and not sinking I would say your fine. Wouldn't hurt to have a peek at the pads though if you haven't in awhile. Link to comment Share on other sites More sharing options...
