9883 Posted July 10, 2008 Report Share Posted July 10, 2008 I have a set of SS lines from FCP groton. They were purchased for the 850 which only comes stock with 280mm rotors. When I recently took a look on FCP website under 98 S70 Turbo section they have two seperate front SS brake lines listed; one for the 11 inch rotor and one for the 12inch rotor, the part numbers are diff. also. However when you look at the kit from IPD there is no ss lines in the kit and no mention of needing different brake lines to fit 302mm onto a previous 280mm application. Link to comment Share on other sites More sharing options...
Marlboroman Posted July 10, 2008 Report Share Posted July 10, 2008 The lines for the 302mm are longer than the ones for the 280mm rotors. However, you can use the lines you have for 280mm rotors if you upgrade to 302mm. I've done that myself, and i know a lot of people who have done the same without any problems. With allt his said, it's of course not a bad idea to get the longer lines, but it's not an absolute must. Link to comment Share on other sites More sharing options...
Yellow95 Posted July 10, 2008 Report Share Posted July 10, 2008 I even used stock length lines with my BBK.Gary Link to comment Share on other sites More sharing options...
Chilled man Posted July 10, 2008 Report Share Posted July 10, 2008 No your fine with the stock SS brake lines Link to comment Share on other sites More sharing options...
