lookforjoe Posted September 10, 2008 Report Share Posted September 10, 2008 I have to amend my original findings - I had a large split in one hose that was limiting overall boost - with that corrected (all new Stylin'Motors hoses) I did a side-by side comparison of the Volvo TCV & the AC Delco...Just testing the first three gears, since I don't want anymore tickets...Volvo TCV (IPD T5M + remap)...1st: 6psi @ 55002nd: 15psi @ 55003rd: 15psi @ 5500Delco TCV...1st: 12psi @ 55002nd: 17psi @ 55003rd: 16psi @5500in the upper 3 remaining gears, boost comes on earlier & stronger than the stock TCV: For example, I get 21psi in 5th @ 3K :) Link to comment Share on other sites More sharing options...
volvo g Posted September 10, 2008 Report Share Posted September 10, 2008 21 lbs? Sheeiittt, I need to get me some of that!You guys think this fix wold work on an S80 (knowing that you guys don't know much about the car) I gotta believe that it should, maybe I'll give it a try with some newly acquired funds. haha.Please let me know who the guy with a 21lbs S80 T6 is, I wanna talk to him and see if his Tranny Bombed yet. I USED A THE END CONNECTOR OF A 91 VOLVO 240 OXYGEN SENSOR, FOUND AT A SCRAP YARDRPM SENSOR CONNECTOR FOR 98 S70 IS THE SAME BUT DIFFERENT COLOR Link to comment Share on other sites More sharing options...
volvo g Posted September 10, 2008 Report Share Posted September 10, 2008 Just to throw the info around out here on this topic: When installing the gm boost control solenoid with a megasquirt the ecu triggers the ground side. So hookup the hot side constant (with an inline fuse) and then the negative side goes to the corresponding pin on MS...S2 on my relay board.can you tell me where the wires go on the gm solenoid? volvo ones are colored. the stock tcv is diffrent physically. any pics would be great, thanks. Link to comment Share on other sites More sharing options...
lookforjoe Posted September 10, 2008 Report Share Posted September 10, 2008 can you tell me where the wires go on the gm solenoid? volvo ones are colored. the stock tcv is diffrent physically. any pics would be great, thanks.Next post down, dude... and earlier in the thread... Link to comment Share on other sites More sharing options...
NEU Posted September 10, 2008 Report Share Posted September 10, 2008 can you tell me where the wires go on the gm solenoid? volvo ones are colored. the stock tcv is diffrent physically. any pics would be great, thanks.Have you read this whole thread? Pix are all over the damn place. :wacko: Link to comment Share on other sites More sharing options...
Deathshead Posted September 10, 2008 Report Share Posted September 10, 2008 wow, looks like im going to be ordering this setup soon! along with a few feet of 4mm silicone vacuum line. Link to comment Share on other sites More sharing options...
db130 Posted September 10, 2008 Author Report Share Posted September 10, 2008 Delco TCV...1st: 12psi @ 55002nd: 17psi @ 55003rd: 16psi @5500in the upper 3 remaining gears, boost comes on earlier & stronger than the stock TCV: For example, I get 21psi in 5th @ 3K WOW!!!We need to get you back on that dyno for revised HP/Torque numbers. Link to comment Share on other sites More sharing options...
lookforjoe Posted September 10, 2008 Report Share Posted September 10, 2008 WOW!!!We need to get you back on that dyno for revised HP/Torque numbers.I know, I no longer have that spike/cut in 3rd that held me back the first time around... ..hopefully later in the fall/early winter - I'm starting my Master's Thesis class this evening, and I'll be buried in research... ..gotta make time for fun, though :rolleyes: Link to comment Share on other sites More sharing options...
NEU Posted September 10, 2008 Report Share Posted September 10, 2008 I can't say there's any appreciable difference in onset or maintaining boostSo would you like to retracted this statement... :lol: Link to comment Share on other sites More sharing options...
