mbsl98 Posted September 2, 2008 Report Share Posted September 2, 2008 I have discovered that the 850/x70 doors are set up to be greased with a typical grease gun, not just by squirting oil on the outside. There is a small bronze colored e-torx plug in the middle of each hinge, seen when the door is open. simply remove those plugs and insert a standard 8mm grease nipple ( I bought a mixed set of nipples at AutoZone for about $3.00), then plug in your normal grease gun. A couple of squirts and the grease comes out the other end of the hinge pin fully coating the whole pin. with no mess. Aopparently you can't leave the grease nipples installed due to space limits inside the door part of the hinge, although it looked as if they would clear on mine. However, I only had two of the right size, so I moved them from door to door. About 10 minutes for teh job, and the doors open really smoothly now. Link to comment Share on other sites More sharing options...
erikv11 Posted September 2, 2008 Report Share Posted September 2, 2008 pin this!!! Link to comment Share on other sites More sharing options...
PaperToast Posted September 3, 2008 Report Share Posted September 3, 2008 pin this!!!i second that Link to comment Share on other sites More sharing options...
volvoskiah Posted September 3, 2008 Report Share Posted September 3, 2008 Thank you! I have always wondered the right way to grease these things Link to comment Share on other sites More sharing options...
Medicman55 Posted September 3, 2008 Report Share Posted September 3, 2008 I'm requesting some pictures. Link to comment Share on other sites More sharing options...
Chilled man Posted September 3, 2008 Report Share Posted September 3, 2008 really you didnt know this ? :o Link to comment Share on other sites More sharing options...
PaperToast Posted September 3, 2008 Report Share Posted September 3, 2008 really you didnt know this ? i never bothered to look so no i didn't. cant have any mercy for the ignorant? :idiot: Link to comment Share on other sites More sharing options...
Geevs Posted September 3, 2008 Report Share Posted September 3, 2008 i don't have a grease gun but do have a spray can of white lithium grease. would this do the job? Link to comment Share on other sites More sharing options...
850&S80 Posted September 3, 2008 Report Share Posted September 3, 2008 Hi All,Too late for me... My center hinge snapped and actually put a slight reverse ding in my door from the inside out.Now the door won't stay open and have to wedge it stay open when cleaning the interior. Do this or else.... Link to comment Share on other sites More sharing options...
WhiteT5 Posted September 4, 2008 Report Share Posted September 4, 2008 Anyone know what size external torx this is and whether or not a deep socket version would work? Harbor Freight has them on the cheap. Link to comment Share on other sites More sharing options...
Pauloil Posted September 4, 2008 Report Share Posted September 4, 2008 ditto..i'd like to know torx also Link to comment Share on other sites More sharing options...
WhiteT5 Posted September 6, 2008 Report Share Posted September 6, 2008 Anyone?11 characters Link to comment Share on other sites More sharing options...
mbsl98 Posted September 6, 2008 Author Report Share Posted September 6, 2008 ditto..i'd like to know torx alsoI just checked and it is an E 8 torx socket. Either short or deep should work fine. Then insert an 8mm greaase nipple and use a standard grease gun fitting. Link to comment Share on other sites More sharing options...
TM850R Posted September 6, 2008 Report Share Posted September 6, 2008 i don't have a grease gun but do have a spray can of white lithium grease. would this do the job?Im wondering the same thing. Maybe one with the little red straw nozzle to attach. Link to comment Share on other sites More sharing options...
