Hellas850 T-5 Posted September 11, 2008 Report Share Posted September 11, 2008 He mentioned 450 up above...that could be his aim.With stock ecu? Link to comment Share on other sites More sharing options...
maciekb2002 Posted September 11, 2008 Author Report Share Posted September 11, 2008 With stock ecu? no custom tune from RICA Link to comment Share on other sites More sharing options...
Auburn T5 Posted September 11, 2008 Report Share Posted September 11, 2008 No NIRA?Also, I may have just skipped over it earlier but what turbo are you using? Link to comment Share on other sites More sharing options...
TBM Posted September 11, 2008 Report Share Posted September 11, 2008 No NIRA?Also, I may have just skipped over it earlier but what turbo are you using?Just a quick remainder, I will run OS2 volvo pistons with Rsport rods first gen, they require cutting cyl sleeves a little, but could be done. I will use gt3071r and siemens 60 lbs injectors, Link to comment Share on other sites More sharing options...
matt b Posted September 11, 2008 Report Share Posted September 11, 2008 Good to see your build still alive, crazy Pole. Did you ask the machine shop if they could acid dip the block for you ? Would have removed all oxidation on it. What paint did you use ?Looks good, the sedan should fly with that set up. Link to comment Share on other sites More sharing options...
Hellas850 T-5 Posted September 11, 2008 Report Share Posted September 11, 2008 no custom tune from RICAWhen I said stock ecu I meant if you will go with another EMS,and not Volvo OEM ECU with chip.Anyway,it is a very good solution if not the only for the OEM ecu.I will do the same,to my car just like you but then I will go and to a dyno for some corrections.Now I don't have money to spend for Aftermarket EMS. Link to comment Share on other sites More sharing options...
turbor850 Posted September 11, 2008 Report Share Posted September 11, 2008 With stock ecu? its possible420 was seen with stock ECU Link to comment Share on other sites More sharing options...
maciekb2002 Posted September 12, 2008 Author Report Share Posted September 12, 2008 today's progress.I redone paint job, and installed couple small thinks like water pump, also I stopped by volvo dealer to pick up new rotors and two more gaskets and O-rings, they are awesome, they have 95% stuff that I need in stock , And R rotors came today another great product made in Poland, Brembo of course, These things are HUGE, It looks like wilwood superlite calipers that I want to use are to small , that was quite a surprise !!!But tomorrow is a big day , Swap is beginning , wish me luck I want to drive my car this Monday , I will do also brand used with low mileage steering rack , bilstein suspension , and maybe front brake conversion , rear is getting done I will use brembo brakes from EVO . Ok let me get some sleep I will have long day tomorrow :D Link to comment Share on other sites More sharing options...
Pwalrus Posted September 12, 2008 Report Share Posted September 12, 2008 This is great, keep up the good work! Link to comment Share on other sites More sharing options...
Hellas850 T-5 Posted September 12, 2008 Report Share Posted September 12, 2008 Good luck and keep us posted Link to comment Share on other sites More sharing options...
JHEIII874T5M Posted September 12, 2008 Report Share Posted September 12, 2008 Looking good, keep up the solid progress. :) Link to comment Share on other sites More sharing options...
sacrifice Posted September 12, 2008 Report Share Posted September 12, 2008 nice work! this may be a stupid question but are you building it by yourself? just curious haha Link to comment Share on other sites More sharing options...
maciekb2002 Posted September 13, 2008 Author Report Share Posted September 13, 2008 yes I am doing it myself, Only work that wasn't done by me so fare was done by machine shop , all the balancing and block cutting Now, this is time for quick update, Engine is out, and some components are mounted to new block . My back is killing me and is 1 00 AM, so it was a long day , tomorrow is next one, I would like to have whole thing assembled by tomorrow night , I did leak down test on head that is now on my car 5% difference, I am surprise that is only 5%car is in the shop getting rid off unnecessary fluidsand let take some parts off two hours latertranny almost ready to bolt back on and block with R clutch , install Link to comment Share on other sites More sharing options...
B Mac Posted September 13, 2008 Report Share Posted September 13, 2008 PM sent.11 Link to comment Share on other sites More sharing options...
Account_Deleted_T5M Posted September 13, 2008 Report Share Posted September 13, 2008 Magic, i can't wait to run you again, maybe we should cruise out to maryland next spring to Cecil County. I'll be running a built motor and gt35r by spring :) Link to comment Share on other sites More sharing options...
