javadoc Posted February 28, 2009 Report Share Posted February 28, 2009 Very wierd stuff today. I pulled my car into the garage this morning to put the summer wheels/tires on, prior to today's GTG. Swapped out the tires, and went to drive the car... won't start. It just cranks, sputters (barely) and you can see a bit of smoke coming out the tailpipes. I checked the fuses for all of the fuel/ignition related bits and they are fine. I even went and replaced them all, just in case. Still, nothing. Nothing appears loose, and if I push the schrader valve on the end of the fuel rail, I get some fuel out. So, I seem to have some fuel pressure (not sure if enough)... appears to be spark, if the car's sputtering. There's no CEL, but I'll hook the car up and check codes, just in case.Any ideas? Link to comment Share on other sites More sharing options...
9883 Posted February 28, 2009 Report Share Posted February 28, 2009 Can the fuel pump be on its way out. Link to comment Share on other sites More sharing options...
javadoc Posted February 28, 2009 Author Report Share Posted February 28, 2009 Can the fuel pump be on its way out.I kind of doubt it but could be. It was replaced 15k miles/ 14mths ago. I'm running 91 octane currently... not any E85. At any rate, I get to crash the Euro GTG in my '64 Chevy. Hahahahaha Link to comment Share on other sites More sharing options...
javadoc Posted March 2, 2009 Author Report Share Posted March 2, 2009 I have swapped coilpacks... no start. Then I pulled codes with my softloader, and here's what I got...ECM-261A: long term fuel trimECM-260A: fuel pressure faultGeneric code that my cheapo code reader gives is P1172... but I'd rely more on the Volvo codes above.My indy-mechanic initially says this could point to the MAP sensor, which I think is weird. An interweb search shows an unrelated Volvo bulletin (Reference Bulletin SMB 23-181, TNN 23-181) for '03 and '04 models. This service bulletin says that a car could in some cases stall out given a faulty fuel pressure sensor... doesn't mention MAP sensor.Anyone have any input? Link to comment Share on other sites More sharing options...
Boost Laggin Posted March 2, 2009 Report Share Posted March 2, 2009 Clogged Fuel filter, Fuel pump fail?Is there gas in it? :lol: Link to comment Share on other sites More sharing options...
9883 Posted March 2, 2009 Report Share Posted March 2, 2009 Start with the cheapest part of the fuel system like the filter and go from there. Link to comment Share on other sites More sharing options...
Boost Laggin Posted March 2, 2009 Report Share Posted March 2, 2009 And if you have any enemies, check the gas tank for anything out of the ordinary. Link to comment Share on other sites More sharing options...
magicaljake Posted March 2, 2009 Report Share Posted March 2, 2009 check you engine grounds Link to comment Share on other sites More sharing options...
javadoc Posted March 2, 2009 Author Report Share Posted March 2, 2009 Clogged Fuel filter, Fuel pump fail?Is there gas in it? Haha, yes there's about 1/2 tank of fuel. I did have a thought yesterday... it can't be out of gas, right?Engine grounds... easy enough to check. Link to comment Share on other sites More sharing options...
dmelviØØ7 Posted March 3, 2009 Report Share Posted March 3, 2009 Unplug your MAF and try and start it. If it starts you need MAF. Link to comment Share on other sites More sharing options...
javadoc Posted March 3, 2009 Author Report Share Posted March 3, 2009 Unplug your MAF and try and start it. If it starts you need MAF.What's really wierd is, I checked for any leaks/loose hoses... found none. Then when my oldest got home, I had her crank the car while I watched under the hood, in case I could see or hear anything. When she turned the key, the car started right up, and has been running perfectly ever since. I have to say, running better than it has in a while. Could it have been something in the injectors? Link to comment Share on other sites More sharing options...
dmelviØØ7 Posted March 3, 2009 Report Share Posted March 3, 2009 What's really wierd is, I checked for any leaks/loose hoses... found none. Then when my oldest got home, I had her crank the car while I watched under the hood, in case I could see or hear anything. When she turned the key, the car started right up, and has been running perfectly ever since. I have to say, running better than it has in a while. Could it have been something in the injectors?I've see that 261A lead to MAF sensors, doubtful if could have been something with the injectors. Link to comment Share on other sites More sharing options...
javadoc Posted March 3, 2009 Author Report Share Posted March 3, 2009 I hear ya Danny. Well, I've always been meaning to keep a spare MAF on hand anyway. Link to comment Share on other sites More sharing options...
1999_V70 Posted March 3, 2009 Report Share Posted March 3, 2009 You say you pulled it into the garage. Was it sitting the driveway before and you just started it up, moved it and shut it down? Could have flooded the engine, I've done this to my V70 and 850 before it. Say I had to move the car out from in front of the garage because someone has to get out, I would start it, move it, and shut it off. Next time I go to drive = no start. Now I just take it around the block. Link to comment Share on other sites More sharing options...
