sconeman Posted March 4, 2009 Report Posted March 4, 2009 I've had the car back from the shop for about two weeks since the last service which included among many other things.. a second, rear (drivers side) cam seal. Ever since they replaced it it's been leaking worse than I've ever seen. A couple of ounces on the driveway every time after we park it.It's going back on Thurs for an inspection but the shop owner says it's probably something more serious than a seal (like an damaged cam shaft) ?? really? It seems like shoddy work is more likely. Opinions?
sconeman Posted March 4, 2009 Author Report Posted March 4, 2009 Are you using an OEM seal?uhmmmm... dunno. shops been doing the job.DOH wrong forum. no wonder I can't find it.
sconeman Posted March 6, 2009 Author Report Posted March 6, 2009 they put a third cam seal in and couldn't find anything else wrong.
MadeInJapan Posted March 6, 2009 Report Posted March 6, 2009 they put a third cam seal in and couldn't find anything else wrong.I always put a bit of RTV around my cam seals when I install them for good measure...seems to help.
Matts 850 GLT Posted March 6, 2009 Report Posted March 6, 2009 I bet they're putting them in backwards. I was doing the same until the parts guy asked me which way round I was putting it in, that also was the third one.Matt
wheelsup Posted March 6, 2009 Report Posted March 6, 2009 just put it in yourself... easy cheezy!I put an OEM Volvo seal in and it still weeps *just a bit*. Just enough to put a drop on the bottom of the cover. It doesn't seem to drop down below but still has me concerned, what sort of sealant can I put around it to hold it better? What sort of RTV sealant? At Autozone they make quite a few different compounds and colors.
--Aaron-- Posted March 6, 2009 Report Posted March 6, 2009 I didn't use any type of sealant on either of my rear cam seals and they don't drip at all.....it's a really easy process.
sconeman Posted March 6, 2009 Author Report Posted March 6, 2009 just put it in yourself... easy cheezy!Doh, I didn't realize how easy it was. They haven't charged me so I haven't lost anything..but oilthanks guys
B Mac Posted March 6, 2009 Report Posted March 6, 2009 I always put a bit of RTV around my cam seals when I install them for good measure...seems to help..........sooooo you seriously GLUE your cam seals in?? Don't do that lol. Just put motor oil or vaseline on them and they should never leak.
Oreo931 Posted March 6, 2009 Report Posted March 6, 2009 .........sooooo you seriously GLUE your cam seals in?? Don't do that lol. Just put motor oil or vaseline on them and they should never leak.Exactly.I lubed mine up and havent had any problems.
7 VII 7 Posted March 6, 2009 Report Posted March 6, 2009 Exactly.I lubed mine up and havent had any problems.wordI will make note of this alsoso just put a bit of fresh engine oil around the seal and put it in flat and flush with the outer surface and you should be good to go
B Mac Posted March 7, 2009 Report Posted March 7, 2009 wordI will make note of this alsoso just put a bit of fresh engine oil around the seal and put it in flat and flush with the outer surface and you should be good to goeverybody but dave has to use oil or vaseline....davey boy has to use jb weld :lol:
