1998 V70 Xc From The Beginning... to the End
Ah ha good sir. I was meaning to talk to you about this particular item. Did you tap a second bolt hole (don't say it) or is a bolt hole there? Did you shave the underside of the tray? I made an attempt at this and would like to fix it.
Are you making it to Carlisle this year?
and wonder how rough the XR is right now? :o
No, holes are all present. Just make a 'tongue' to extend from the rearward bolt into the channel of the tray as pictured. Much material has to be shaved from the underside, you want the tray to set as level as you can get it. The last thing, is that there is a 700/200 auto brake pedal pad stuffed under the front fender side of the tray to level it & prevent the tray flexing there.
Definitely gonna be @ Carlisle, got my pass & Travelodge room is reserved for my son & I.
Not sure what you mean by 'how rough the XR is right now?". It's all good, except that the tune needs tweaking more for the extra CFM's.
TT COP will be installed during the week, I need to modify his harnesses to fit the modules the way I want them - inside the ECU box & out of sight.
I'd like to have the KU SM flywheel done before then, but I'm sure it's gonna have to wait 'til the summer, if not even later in the year.
Seemed like it needed a fair amount of things done judging by the parts you had laid out. Good to hear you are making the show.
Oh - I see. :D That was just the visual list of parts needed for the late model head swap. :lol:
How many times have you pulled the engine out? Your car is insane by the way...love it.
My real question is from several pages back...where did you get the heat elements for the rear seats?
Engine was only removed once - two + years ago when I put in the built motor. Apart from that, this is the first time in 25K+ miles the head has been removed from the block.
The heater elements came from an eBay seller, they have kits in different sizes. I'll take a look through my older receipts & try & figure out who/where it was.
EDIT: My Heater Install Thread has all the info you need to search for the pads..
  • 2 weeks later...
Now with TTCOP - after figuring out the cam sensor plate HAS to be in the stock reference location (Enem cams are set somewhat off)
http://i27.photobucket.com/albums/c190/huseinholland/cars%20cats%20houses/IMG_8809.jpg
removed (and sold) all these items
running
http://i27.photobucket.com/albums/c190/huseinholland/cars%20cats%20houses/th_2011-05-07215024.jpg
'03 Dual VVT head install parts list:
Part numbers can be checked Here
Head Gasket 9443896 -for B5234T3/B5244T4/5
Head Bolt x12 6842347
Solenoid Gasket x2 30731212
Cam Cover Oring x5 1397525
Int Cam rear cover 1397381
Chemical Sealer 1161059
Rear Cam Seal x2 9443310
Front Cam Seal x2 9458309 (single VVT int seal is different - 9440651)
Valve Seal x20 9443787
T/Stat Housing Gskt 9463274
T/Stat seal 6842214
T/Stat (180ºF) 431-35378 (Stant) bottom bypass
T/Stat (160ºF) 431-35376 (Stant) bottom bypass
T/Stat (180ºF) 431-45378 "superstat" same as OEM
Water Pipe Gskt 1236119
Int Manifold Gskt x2 9458534
IPD Phenolic Spacer
M7x40 bolt x 7
Exh Manifold Gskt set 271802
Exh Studs x10 982667
Exh Nuts x10 985868
T/belt Idler 8630590
T/belt 274338
T/belt Tensioner
Ahjehr VVT Delete Hub(s)
Cam gear x2 9180721
Cam gear bolts x6 982758
Cam Hub Bolts x2 980734
Torque Mount
Torque Mount lwr Brkt
Engine Cover Parts:
Outer Cover
Top Cover
Inner Cover: 30731950
Clips x2 9454716
Protecter (axle) 9125469
Lower Belt Protector 9189227
Injector Cover 8658235
'99- Tensioner setup:
Serpentine Belt 6DPK-1824
Tensioner Pulley 8627944
99- Reservoirs
Coolant Res. 30741975 old sensor fits, not included
PS
Tower Bracket 9444711
COP parts:
TT COP module
TT COP harnesses
TT COP ECU
Harness to Coils
Harness Isolater 9469243
Coils (IPD) Bosch Motorsports
  • 1 month later...
EDIT:
Got the Motegi 116's (ET45) installed, need 4mm spacer to clear BBK w/1mm clearance. Tuner lugs & 65-70mm hub adaptors. Did the mirror directionals a few weeks ago.
Magnaflow 14419 resonator
3" all the way
Magnaflow 14834's
They look good! Not a whole lot different then the pegs :lol: \
Did you do a weight comparison?
2lbs lighter, wheel w/tire. No, not much visual difference, and between spline lugs, spacers & hub adaptors, a bit of a PITA. But, they are coated black & the red is recessed in the lip, so I won't be scratching it.
Your wagon is still changing rapidly! :lol:
Do you think that Magnaflow decal will be destroyed by the heat? That's a pretty neat location for it.
Thanks. :D
Yeah, it will burn off. It's already flaking after couple hundred miles.
LGSpeed Header & getting the KU SM flywheel will be the next mods, unless nathaninwa can get my intake manifold done before the end of the summer
