1998 V70 Xc From The Beginning... to the End
I would like to convert my V70 to AWD, I found one m66 online but it's $3k!!! Where'd you source yours from?
VandSautodismantlers
So the fronts are almost bottomed out?
Yep. At this point, I get pretty significant inner fender rub. I can stall the motor on a hard (full lock) slow turn. Inner liners are worn through above the wheel.
  • 3 weeks later...
Was getting wheel hop in 3rd & 4th on the highway, so I moved up the Quaife 14J install in the spare M66 I bought
Installed new Volvo control arms, and a replacement PS rack at the same time, since toe changes can induce hop
Trans going back in
I also was getting some clutch slip under high load, so I removed the PP shims, and had the KU SM flywheel remachined to the correct offset for the Spec Stage III full face (.353"/9mm).
Have about 200 miles since the install, so too early to tell if the wheel hop is a done deal. Once the flywheel is bedded, I'll get on it hard & see what's up. Since the problem was less apparent with the 17's & snows, I also bought some new Enkei M52's 17x7.5 ET38, to put on instead of the 18's. I wanted something else just for back up anyway.
Which car, the '99? Are you coming to Carlisle next year/ I missed your cooking this past year biggrin.png
I like that idea.
I'll have to discuss it some.
I'm also putting in a larger intercooler - my 3.5" core is currently swedged between the bumper & AC cond - so I'm going to go with a 31x12x3 (vs. 28x8x3.5) which will give a smidgeon of breathing space on either side. It will mean cutting out the valance & tie bar...
Hello lookforjoe
I have a question about your intercooler:
Today you have chosen to put a large (28x8X3, 5 ").
I see that opening in your bumper can cool up to your intercooler. It is therefore a good choice.
I have a Volvo V70R AWD and I can not put your model because the cooling is not optimum, the opening in the bumper is too small ....
I will change because the original intercooler is misplaced, I look at what is on the internet where the forum VOLVO ...
I think rather direct me to the first intercooler you'd first (28x8x3, 5 ") since opening in my bumper is 22.4" Lx3, 14 "D.
From the opening of the bumper I make aluminum plates to direct air over the surface of the intercooler.
Were you satisfied with your first FMIC (28x8x3, 5 ")?
How much power can it handle? 350 hp max or more? 400 hp
Thank you in advance for information
Yann
On 4/14/2013 at 10:33 AM, rise94 said:
Hello lookforjoe
Yann
Hi Yann
This smaller size can handle 350BHP. However, you need to look for Treadstone, Precision, etc with a medium density core. eBay coolers do not have internal fins that support optimal cooling. You can add deflectors like this:
to assist in even air distribution
Current bay pics
  • Upvote 3
  • 2 weeks later...
Small update. Clutch still slips at peak torque at pretty much any boost setting over base (14psi) WG. I had already scheduled the AWD Dyno session, so I did a couple highway pulls to see what rpm level I could proceed to WOT with slip. I found that over 4500 was safe, but this means the graphs do not reflect peak torque since that occurs below WOT . Good news is The intake, header and .82a/r hotside give me an EBR of less than 1:1, so I should be in great shape once VEMS is in and I turn up the wick.
Dyno from today; Limited to approx 18psi on 2nd pull, as stated above, had to hold off from WOT until over 4500 or instant slip. 1st pull was at WG pressure - about 14psi
Just over 408AWD WHP@ 7,925 rpm. They said if you want to compare to DynoJet, etc, you'd have to add approx 18%, as this one doesnt apply all kinds of correction factors to bump the numbers.
5DB31559-8ADE-4EC0-89A0-A69822A76004-620
  • 2 weeks later...
as always nice work Hussein ...looks awesome :tup: ...408 :blink: wow ! did you take it to a track and see what it does on 1/4 mile yet?
Thanks -
No, between the wheel hop & clutch slip @ peak torque there is no point until that is fixed.
